You can now order the forum stickers. Login and go to the "members only" forum. This is not available for guests yet....
1Back to top Go down    Help with ht lead I.D on Sun Oct 06, 2013 7:18 am
colinijohnson
Hi- I switched ht leads to realmengineering ones. Could someone please help explain which plug lead goes from which plug to which coil socket. I'm checking because I may have mixed them up!
The bike was running rich on 2 plugs and I've just had to replace the Coil that serves cyl 2&3 with a good used(orAnge) one. Bike now pulls great at high revs, but needs warming up from cold or it stalls. I'm gonna renew plugs, check t p s switch and Ecu connections. All obvious other bits have been done over last 2 years...temp switch, breather hose , cleaned connections, tb,s balanced. The only other thing is maybe the battery's crap - even tho only 2 years old.
Any other thoughts would be gratefully received
Colin
2Back to top Go down    Re: Help with ht lead I.D on Sun Oct 06, 2013 11:05 am
front coil = 1 and 4
rear coil = 2 and 3
3Back to top Go down    Re: Help with ht lead I.D on Sun Oct 06, 2013 11:09 am
colinijohnson
Thanks Charlie- does that mean no 1 goes to the spark plug on the furthest left? Sorry for my ignorance...
k100lt 1989 abs
4Back to top Go down    Re: Help with ht lead I.D on Sun Oct 06, 2013 11:32 am
the.postman
@colinijohnson wrote:Thanks Charlie- does that mean no 1 goes to the spark plug on the furthest left? Sorry for my ignorance...
Inline Engines are normally numbered from the front of the vehicle, so yes, looking at the plugs number 1 is the furthest left.
1985 K100 RS 104EA49840092 #0081788 SILVERish (Madison) Prod. date 05/12/84
1984 srx 600
1986 cbr1000f/h
