Timber
Timber
Hi guys, I have a warped right front disc. Does anybody have a straight set or a right disc with at least 4 mm left?
And willing to send it to the Netherlands of course....
I have been searching here in Holland but there's not much for grabs.
It's for my 1984 K100RT
Tim
Good discs are getting very hard to find Tim you may be best off to bite the bullet and get a pair of new EBC fully floating, they are a much better disc than OEM but like anything else new for a K, expensive.
did you have a look at motobins for their new "economy range "  from grimeca ...quite cheep relatively
http://www.motobins.co.uk/bmw-parts.php?model=K Series
just a heads up
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%OBrake discs needed for a K100RT 1984 (no ABS) Au-log10
Brake discs needed for a K100RT 1984 (no ABS) K_disc10
the post can be an issue...at that weight.
KKlompy Brake discs needed for a K100RT 1984 (no ABS) 2854237993
Try your local BMW dealer before ordering from the UK. I have found most things are cheaper for our old bikes and there is no postage and packing from the dealer.
Also check out EBC rotors.
They have; http://www.hobbyist.nl/
For more Dutch K-people https://www.facebook.com/groups/bmwkvriendengroep/
International; https://www.facebook.com/groups/33247767332/
And our new-started forum http://allparts.pro/
(This forum is better, but we're on our way Wink)
ldrotpk
ldrotpk
Not sure of what postage would run. but I have 6 front rotors ranging from 3.93mm(.155) to 4.17mm(.164).
Kevin
Omaha NE USA
@ldrotpk wrote:Not sure of what postage would run. but I have 6 front rotors ranging from 3.93mm(.155) to 4.17mm(.164).
Kevin
Omaha NE USA
Priority Mail International® Medium Flat Rate Box - $59.95
