1Back to top Go down   S 1000 RR forks Empty S 1000 RR forks on Tue Nov 12, 2013 2:35 pm
wickbimmer
wickbimmer
I have seen several posts about changing the K's forks to an inverted type fork. My question is would the forks from the S1000RR swap out?
2Back to top Go down   S 1000 RR forks Empty Re: S 1000 RR forks on Tue Nov 12, 2013 3:40 pm
MikeP
MikeP
Given the diameter of the upper fixed tube, I'd say that it would require S1000RR triple clamps/steering stem. The key to fitting them would be the steering-head bearing compatibility with the existing headstock tube.
Checking the part numbers, they are only listed for the S1000RR and HP4. No doubt as the new NineT uses the same forks, it will use the same steering stem and bearings too.
1992 K1
3Back to top Go down   S 1000 RR forks Empty Re: S 1000 RR forks on Tue Nov 12, 2013 4:16 pm
wickbimmer
wickbimmer
That sounds way easier than the Suzuki swap. I'm guessing a bit more expensive though.
4Back to top Go down   S 1000 RR forks Empty Re: S 1000 RR forks on Tue Nov 12, 2013 5:52 pm
@wickbimmer wrote:I'm guessing a bit more expensive though.
Doubt that given the number of S1000RR's that get crashed from noobs and squids (many SS bikes for that matter).
