1Back to top Go down   my 87 LT conversion Empty my 87 LT conversion on Sat Nov 16, 2013 8:20 pm
snowbeard
snowbeard
well I thought I would also add a thread on here, if only to remember what I've done for my own poor memory!
long story short, I was given an '88 K100LT that resided in Scotland (I was living in Portugal at the time) and rode it home over the course of two weeks.
first siting in the shed
my 87 LT conversion Pbucket
waiting for the ferry
stop in Spain
home in Portugal, looking to get new shoes on 'er
the things I had to do to get by in Portugal, getting the new rubber mounted (saved some dosh by removing my own wheels in the lot, the bike was my only powered transport!)
and some great rides around Portugal.
Now that I've moved home to the states I wanted to replace the big bike with another fast, stable, reliable daily rider. I had given my old GS650G to the same fellow who gave me the K, so I needed something that I wanted to take on longer rides than my trusty '57 BSA
After some time searching I came across this from a non-rider, no tool using fellow who needed a new car
more to come!!
2Back to top Go down   my 87 LT conversion Empty Re: my 87 LT conversion on Sat Nov 16, 2013 10:04 pm
a good start
enjoy the journey
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%Omy 87 LT conversion Au-log10
3Back to top Go down   my 87 LT conversion Empty Re: my 87 LT conversion on Sun Nov 17, 2013 1:55 am
snowbeard
snowbeard
Thanks man!
So on to the new work! The headlights are just placeholders, made from a set of Hella fog lights. They went on within moments of getting it home just to see how they would go. Later they got straightened and the deflectors removed to give better light, but they're still not great.
After that was a final drive oil change, new crush washer. New oil filter and crankcase oil, new air filter, new spark plugs (finally!) and new AGM battery. After unplugging and repluging the under seat EFI unit, and some clean up and insulation of the plug caps, she's running quite nicely.
New horns from EME, as well as the battery and air filter. Lucky me they are just down the road a bit! get to save on shipping and visit when I need things.
With the new lights the dash looked really awkward so thanks to bushyintas' brilliant idea I made some brackets that dropped it a few inches to be right above the lights. It actually stayed directly in the line of sight that it was, so I don't even lose function. It was wobbly as all get-out at first, but a couple of rubber bumpers to help brace it have cleaned it up nicely.
added some random old flasher housings that I had lying around, used the inards from the flashers on the fairing bunged in. they won't be some people's cuppa but I like to have signals that are big and visible... if only from the side they matter on!
I was worrying about the radiator after removing the fairing and grill, but luck would have it I passed a roadside cleanup that included a few sheets of stretched steel grating, mostly run over when it blew off a truck, but with enough salvageable to cut my new grate. Also added a piece of window screen on the airduct to keep out a few more bugs and leaves...
So I got out today with some early morning sunlight and got some scenery shots in front of the Flatirons by NCAR.
so that's where it stands today. Still want to replace plug caps/wires and add the crash bars that were part of the fairing, paint the front forks and engine at some point, but as she starts and runs ok so far, those are for slow times.
always more to come as I just can't keep my hands off motorcycles!! Wink
Cheers!
4Back to top Go down   my 87 LT conversion Empty Re: my 87 LT conversion on Sun Nov 17, 2013 5:11 am
k-rider
k-rider
nice job there , i am wondering , what is the net n the tank for?
5Back to top Go down   my 87 LT conversion Empty Re: my 87 LT conversion on Sun Nov 17, 2013 5:44 am
bushyintas
bushyintas
Nice job on the instrument bracket, keep up the good work, love the photos.
Just a thought, maybe even drop the headlights even more, just level with the bottom of the triple tree, instruments as well to match, then the lines of the lights will flow across to the tank making it look sleek. Also this will close the gap between the lights and your front mud guard.
Bushy
6Back to top Go down   my 87 LT conversion Empty Re: my 87 LT conversion on Sun Nov 17, 2013 9:25 am
snowbeard
snowbeard
the net is to hold the tank on! Shocked   just kidding, its just because I found it in the garage and it is handy to put my gloves under, or if I get something out-n-about that needs to be held in place... Wink
Bushy, that's an idea, I'll see how it goes and if there's a need for bracket V2.0 it may go that way...
7Back to top Go down   my 87 LT conversion Empty Re: my 87 LT conversion on Sun Nov 17, 2013 5:52 pm
Nice work Snowbeard. I like the Colour coded knee pads too. Envious of the trips around Portugal. Would love to get there - maybe the naked k75 will provide the opportunity (if I ever get around to doing it up).
my 87 LT conversion Ir-log11 88....May contain nuts!my 87 LT conversion Ir-log11
8Back to top Go down   my 87 LT conversion Empty Re: my 87 LT conversion on Sun Nov 17, 2013 7:13 pm
A lovely conversion........giving me ideas.......
9Back to top Go down   my 87 LT conversion Empty Re: my 87 LT conversion on Tue Nov 19, 2013 1:38 am
snowbeard
snowbeard
it is nice to have some air flow, although here in Colorado right now the fairing might be nice!!
just to document everything done, I also bought a tap and tapped threads into the holes to fit this POS Japanese mirror that I had laying around. Just saw a whole set of bar clamps on ebay while perusing K100 parts and thought of it!
10Back to top Go down   my 87 LT conversion Empty Re: my 87 LT conversion on Fri Apr 04, 2014 4:13 pm
snowbeard
snowbeard
not too much new, but finally got around to a quick rattle can refresh of some of the black bits that weren't
caught a nice day in CO (not hard to do in fact) and got some pics
my 87 LT conversion Pbucket[/URL]
had to change the brackets I had made for dropping the instruments as they were too light and made things wobble. that's what is poking out under the lights now. I used a random hardbag mounting bracket that I didn't want to cut in order to test it, so V3.0 will have to be found at some point. :-)
