1Back to top Go down   anti puncture slime. Empty anti puncture slime. Thu Nov 14, 2013 9:20 pm
aeronut7
aeronut7
hi all.....does anybody here use that anti puncture slime in their tyres.
theres lots of good reviews and lots of bad reviews on this subject
I might be tempted to use it as im pretty sure I have a slow puncture on my front tyre and still got a couple of thousand miles left in them....I want to replace both tyres in the new year cos id prefer to have the same make not mismatch tyres....
any coments would be greatfully received....
2Back to top Go down   anti puncture slime. Empty Re: anti puncture slime. Thu Nov 14, 2013 9:53 pm
I have found that most of them work but be prepared to clean up a mess when you remove the tyre
3Back to top Go down   anti puncture slime. Empty Re: anti puncture slime. Fri Nov 15, 2013 2:58 am
the.postman
If its a puncture.... get it sorted.
its easy to check elsewhere on the wheel for air leaks.... Round the beading... at the valve.
When it is time to get new boots give these guys a try
Tyre Tec Trading
Mail order, usually a great deal with fast friendly service.
1984 srx 600
1986 cbr1000f/h
4Back to top Go down   anti puncture slime. Empty Re: anti puncture slime. Fri Nov 15, 2013 3:09 am
You could fill the bath with water and check for leaks/bubbles. Only checking a portion at a time otherwise the bearings may be exposed to water.
Next I would check/replace the valves. They could be loose and just need a torque.
Next I would take the wheel to the tyre shop and ask them to reseat the tyre. ie break the bead and reseal.
In the interests of your health, seek permission before using the bath. :bom:
Cheers, Dave
5Back to top Go down   anti puncture slime. Empty Re: anti puncture slime. Fri Nov 15, 2013 3:39 am
aeronut7 wrote:I want to replace both tyres in the new year cos id prefer to have the same make not mismatch tyres..
This is a non-issue unless you're concerned about vanity.
6Back to top Go down   anti puncture slime. Empty Re: anti puncture slime. Fri Nov 15, 2013 5:00 am
The tyre dealers will always tell you to have a matched pair of tyres and a set of 4 on the car that way they make more money.
The only time it is fairly important to have a matches pair of tyres is on a car with a LSD because if they are not very close to the same diameter the differential clutches will always be slipping against each other and wear out.
7Back to top Go down   anti puncture slime. Empty Re: anti puncture slime. Fri Nov 15, 2013 5:04 am
TacKler wrote:You could fill the bath with water and check for leaks/bubbles. Only checking a portion at a time otherwise the bearings may be exposed to water.
Cheers, Dave
lol!
8Back to top Go down   anti puncture slime. Empty Re: anti puncture slime. Fri Nov 15, 2013 1:14 pm
I use Puncturesafe (previously known as Ultraseal) in my wheels.
A couple of years ago I pulled an 1½" nail out of the back tyre of the outfit without any loss of pressure, so I'm convinced that it works.
On the down side, I have heard of corrosion occurring, but I've never experienced any in all the years that I've been using it.
9Back to top Go down   anti puncture slime. Empty Re: anti puncture slime. Fri Nov 15, 2013 7:31 pm
I've used it to fix mystery slow loss of pressure.  I'm certain it works for punctures too.
I do have a problem though, My front wheel is hard to balance and makes the front end shake a bit at speed, the dynamic balancing machine gives a different weight required every time they spin the wheel. I'm fairly sure that the puncture goo is the problem.
When the tyre comes off to get the wheel checked and straightened(there is a bit of out of round but that doesnt explain the inconsistent results) I wont be putting the goo back.
anti puncture slime. K-dogs10
10Back to top Go down   anti puncture slime. Empty Re: anti puncture slime. Sat Nov 16, 2013 2:11 am
bushyintas
bushyintas
I ran 'slime' in my old XJ750 and when I got the tyres changed there was a large build up of corrosion on the rim from inside where the 'slime' came in contact. the mechanic said that he had seen this corrosion so bad that the bead had nearly rusted through. No more ''slime'' or any other repair gel, I carry a plug kit for emergencies and that's it, your rubber is the most important piece of equipment.
bushy
11Back to top Go down   anti puncture slime. Empty Re: anti puncture slime. Sat Nov 16, 2013 2:36 am
the.postman
bushyintas wrote: your rubber is the most important piece of equipment.
bushy
Too true......
Rubbers save lives....!!!!!!!
1984 srx 600
1986 cbr1000f/h
12Back to top Go down   anti puncture slime. Empty Re: anti puncture slime. Sat Nov 16, 2013 3:30 am
k-rider
k-rider
well , i have used it a couple of times with great result , didnt have to buy a new tire from the Holiday budget,  and im not sure that the corrosion bit is a problem with our alloy Wheels?Question
13Back to top Go down   anti puncture slime. Empty Re: anti puncture slime. Sat Nov 16, 2013 10:17 am
MikeP
MikeP
Aluminium will corrode. It just doesn't rust.
1992 K1
14Back to top Go down   anti puncture slime. Empty Re: anti puncture slime. Sat Nov 16, 2013 10:49 am
I use it in my wheel barrow and my bicycle, but would not put it anywhere near any of the motorcycles.
15Back to top Go down   anti puncture slime. Empty Re: anti puncture slime. Sat Nov 16, 2013 11:31 am
MikeP
MikeP
Me neither but each to his own.
1992 K1
16Back to top Go down   anti puncture slime. Empty Re: anti puncture slime. Sat Nov 16, 2013 12:21 pm
the.postman
I think I would only use it as you would a space-saver tyre on a car.... just to limp home and change asap.
1984 srx 600
1986 cbr1000f/h
