1Back to top Go down   Advice on rear shock replacement Empty Advice on rear shock replacement Tue Nov 26, 2013 11:11 pm
keeper
My rear shock is leaking. Just wondering if there is an affordable option to the $550 BMW unit, if it's even still available? I've looked on line and cant' find a used one. So far I've found an IKON for $600, a Progressive for $450, a Hagon for $500, and a Realm for $350. What do you folks recommend for a light weight rider, bumpy roads and a thin wallet?
Ralph
Every day is a new adventure.
1987 K100RS; 1978 Yamaha TY175 (trials)
2Back to top Go down   Advice on rear shock replacement Empty Re: Advice on rear shock replacement Tue Nov 26, 2013 11:28 pm
JR_K100RS
JR_K100RS
Eh Ralphy Boy , you want to get the RAM shock ( Realm Engineering ) this is not based on price , it is the pick of your bunch , most here will agree
JR ( channeling the "Honey Mooner's" )
3Back to top Go down   Advice on rear shock replacement Empty Re: Advice on rear shock replacement Wed Nov 27, 2013 12:35 am
The realm engineering RAM SHOX is by far the pick of the lot but whatever you do DON'T buy an IKON they are plagued with trouble the main one being the shaft breaking at the top eye. I personally know of 3 with that have broken and one other where the spring colapsed and so did the replacement spring. I have heard of several others also breaking the shaft.
4Back to top Go down   Advice on rear shock replacement Empty Re: Advice on rear shock replacement Wed Nov 27, 2013 12:42 am
beanoldboy
beanoldboy
i concur , realm springs front and back .
http://www.airware.com.au
5Back to top Go down   Advice on rear shock replacement Empty Re: Advice on rear shock replacement Wed Nov 27, 2013 1:56 am
I like the RAM shock too.
One caveat:  The default is that it comes with a spring for two-up, fully loaded riding.  It was way too stiff for me one-up with minimal luggage loading.  I contacted them and had them provide me with a "lighter" spring for just me.  Worked much better that way so if you order one then be sure to tell them what the normal load will be on your bike so that they can spring it properly.
6Back to top Go down   Advice on rear shock replacement Empty re Wed Nov 27, 2013 5:33 am
colinijohnson
colinijohnson
Yes the Ram is the best.
I fitted the Hagon, which worked ok, but had to go back under warranty - and then developed a problem, which they diagnosed as me fitting it the wrong way up!
I also tried a 2nd hand ICON at one point. which made the bike very tall and was very bouncy - probably faulty
No probs with the RAM todate
Last edited by colinijohnson on Fri Nov 29, 2013 4:54 am; edited 1 time in total (Reason for editing : fitted Hagon not Icon!)
k100lt 1989 abs
7Back to top Go down   Advice on rear shock replacement Empty Re: Advice on rear shock replacement Wed Nov 27, 2013 7:25 am
Tenox
Tenox
I have a Hagon and I have been satisfied with it.
SUA50848 I think is the model - can be found here:
http://www.motorworks.co.uk/vlive/Shop/Parts.php?T=5&NU=15&M=40&Ct=MA&SbCt=BA_15_40_MA_65
BMW K100RT Scrambler (86)
8Back to top Go down   Advice on rear shock replacement Empty Re: Advice on rear shock replacement Wed Nov 27, 2013 7:28 am
japuentes
japuentes
Hi there, I wanted the RAM, but due to shipping & customs had to go with the Progressive´s  465 model. I´m really happy with it.
Best regards
JAP
Advice on rear shock replacement 2854237993 1988 K100RS SE/ABS
9Back to top Go down   Advice on rear shock replacement Empty Re: Advice on rear shock replacement Wed Nov 27, 2013 7:25 pm
Comberjohn
Comberjohn
Ram would be the choice, but for those with a thin wallet check out the Bilstein replacement damper from James Sherlock.
Not hard to do. Just need a big hammer and a small cold chisel. I've done it and the result is OK. Similar to putting a new original shock on.
Says that they don't post to North America but not sure if that includes Canada. If it does, maybe it could be sent via someone in the UK.
Life is not a rehearsal.
2010 VFR 1200F DCT
2010 R1200GS(gone)
1986 K100 Silver(gone)
2012 K1600GT(gone)
1984 K100 Red(gone)
10Back to top Go down   Advice on rear shock replacement Empty Re: Advice on rear shock replacement Wed Nov 27, 2013 8:00 pm
tio Jaimito
tio Jaimito
RicK G wrote:" but whatever you do DON'T buy an IKON they are plagued with trouble the main one being the shaft breaking at the top eye. I personally know of 3 with that have broken and one other where the spring colapsed and so did the replacement spring. I have heard of several others also breaking the shaft."
Add another horror story about IKON.   this last summer we finished a tour thru southern Wisconsin with Motobricks crowd and on their way home a couple busted the IKON off their k1100rs  which  ribboned their rear tyre instantaneously  they wallowed on to the gravel shoulder at 40mph then high sided totaling their bike and leaving them both with minor hospitalization.    She swore off riding.  bad shock.
Krazy Kat. 1985 K100RS Alaskablau 13000miles 8valve "Black Belly"
Peggy's 1987 K75s Columbia Grey 9500miles 6 valve.
Advice on rear shock replacement K100_m12
Advice on rear shock replacement K75_po12
Advice on rear shock replacement Basil_10
http://www.nachicagonorth.com
11Back to top Go down   Advice on rear shock replacement Empty Re: Advice on rear shock replacement Wed Nov 27, 2013 10:38 pm
keeper
As usual lots of good advice. Thanks everyone. I'm off to print some more cash.
Ralph
12Back to top Go down   Advice on rear shock replacement Empty Re: Advice on rear shock replacement Wed Nov 27, 2013 11:14 pm
Dont forget to send me some!
