1Back to top Go down   Wiring - current carrying capacity Empty Wiring - current carrying capacity Fri Nov 22, 2013 4:13 pm
Kioors
Kioors
Hey guys.
I was just installing Oxford heated grips on my 100RS16v. All is finished now, and after a testride everything seems to be working! Great!
But...
I didn't connect the power supply of those grips directly to the battery, as the manual told me, but to the connector for OEM heated grips. (so they don't drain the battery when left on!). While doing so, I felt like the wires going to that connector were really thin, and now I start to wonder how much current I can draw through without setting fire to the tank!
Thus, the question is: What power rating do the OEM heated grips have? (oxford claims theirs are 50W max)
Or maybe I should put it more general and useful for everybody: what's the cross section of those wires (and 90% of the rest of the wiring), and what is the maximum current allowed?
Thanks a lot!
1989 K100RS 16v
1991 K100RS 16v - For sale
1993 Ducati 750 SS - For sale
1992 Ducati 907i.e.
About 22W per side for OEM HGs.
3Back to top Go down   Wiring - current carrying capacity Empty Re: Wiring - current carrying capacity Sat Nov 23, 2013 10:56 pm
The thinist wire used on a K is 0.5mm and that will carry 5 amps without problems so at 50watts you will only draw 4.2 amps then all should be OK.
