1Back to top Go down   2nd hand speedo for the 84 k100rs Empty 2nd hand speedo for the 84 k100rs on Thu Nov 28, 2013 6:46 am
mongoX
Hi does anyone know if the speedometers are interchangeable thru the years.
My 1984 k100rs speedo doesn't work . im looking for a 2nd hand one  but wonder if the wiring at the back uses the same connectors
thanks
2Back to top Go down   2nd hand speedo for the 84 k100rs Empty Re: 2nd hand speedo for the 84 k100rs on Thu Nov 28, 2013 7:08 am
the late 85 and further on have a different fuel sender and electronics ....
so yes it may fix the speedo ...but you may have to exchange some boards internally to get the fuel warning light to work
hope that helps
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%O2nd hand speedo for the 84 k100rs Au-log10
3Back to top Go down   2nd hand speedo for the 84 k100rs Empty Re: 2nd hand speedo for the 84 k100rs on Thu Nov 28, 2013 8:07 am
The wiring for the 85- and 86+ instrument clusters is identical with the following exceptions:
On the early cluster pins 7 and 8 are brown/white and brown/black for the two fuel level sensors.
On the later clusters pin 7 is white from the newer fuel level sender and 8  is green/yellow for the ABS warning lamp.
On an 85- cluster the warning lamps under the speedo will be red and yellow, On an 86+ ckluster both will be red.
4Back to top Go down   2nd hand speedo for the 84 k100rs Empty Re: 2nd hand speedo for the 84 k100rs on Thu Nov 28, 2013 12:33 pm
brickrider
brickrider
Your level of K-bike knowledge never fails to impress! Very Happy
5Back to top Go down   2nd hand speedo for the 84 k100rs Empty Re: 2nd hand speedo for the 84 k100rs on Thu Nov 28, 2013 1:24 pm
ReneZ
ReneZ
I have done it without issues. Indeed, you'll loose the fuel warning lights, but most only get irritated by the 7 litres one and tape it off. A good day counter works just as well.
Greetings from Florida! Having a 'new' K  :cyclops:    Surprised-o:
Rene
BMW K100 - 1985 (0030029) 2nd hand speedo for the 84 k100rs Rain
BMW K1200GT - 2003 (ZK01223)
