1Back to top Go down   Oil Light Empty Oil Light on Thu Dec 12, 2013 7:22 pm
klamityboy
klamityboy
I noticed today that the oil light in the instrument cluster was faintly lit today. Here are some datsa points:
- instrument light bulbs upgraded to LED
- oil changed 2500km ago
- oil still visible in middle of sight glass
My question is if the sensor is starting to fail or if this is symptomatic of something else?
Klamityboy
1991 K75RT-P
Model Description: K 75RT
Market: Europe
Type: 0565
E-Code: K569
Engine: 3_ZYL - 0,70l (55kW)
Transmission: Manual
Body Color: Polizeiweiss
Production Date: 30.08.1990
2Back to top Go down   Oil Light Empty Re: Oil Light on Thu Dec 12, 2013 7:33 pm
I would guess you find the problem at the sensor, or a partially shorted (to ground) wire
between the sensor and the cluster.....disconnect the switch to check.
But if high mileage/unknown history, it won't hurt to have the pressure checked.
3Back to top Go down   Oil Light Empty Re: Oil Light on Thu Dec 12, 2013 8:54 pm
wonder if the cable to the sensor has been crushed somewhere .....?
maybe through the timing cover to the HES (hall effect sensors)  ?
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%OOil Light Au-log10
"redframe" rs "bitsa"  with many contributions from the k100 community ,,with many thanks
4Back to top Go down   Oil Light Empty Re: Oil Light on Fri Dec 13, 2013 5:29 pm
klamityboy
klamityboy
Another Data Point.
Yesterday was raining quite hard when the light was faintly lit. Subjectively the light seemed to grow in intensity but was never 100% on. Today is dry and no light. I am thinking this is pointing towards the connection between the wire and sensor, or just the sensor.
Thoughts?
Klamityboy
1991 K75RT-P
Market: Europe
Type: 0565
E-Code: K569
5Back to top Go down   Oil Light Empty Re: Oil Light on Fri Dec 13, 2013 5:49 pm
I would guess that the moisture have partially shorted the connector(s) at the sensor.
Clean the outside of the sensor, give the connectors a sqiurt of WD40 (or similar),
put back the rubber cap...wait for the next shower...or use the garden hose.
6Back to top Go down   Oil Light Empty Re: Oil Light on Fri Dec 13, 2013 6:06 pm
klamityboy
klamityboy
@Inge K. wrote:I would guess that the moisture have partially shorted the connector(s) at the sensor.
Any thoughts on dielectric grease in the rubber cap after the connectors are cleaned?
Klamityboy
1991 K75RT-P
Market: Europe
Type: 0565
E-Code: K569
7Back to top Go down   Oil Light Empty Re: Oil Light on Fri Dec 13, 2013 6:18 pm
LED bulbs sometimes glow when used in a circuit with an earthed on/off switch such as the oil pressure one. I have LED interior lights fitted to my car and sometimes they glow at night. I think that because they need so little power, they can find a slight earth just from moisture in the air.
I don't think that there is anything wrong with your oil system at all.
8Back to top Go down   Oil Light Empty Re: Oil Light on Fri Dec 13, 2013 6:24 pm
D.e.grease could be a good idea where the i.d. of the rubber cap contacts the sensor,
and where the wire enters the rubber cap.....used sparingly.
Dielectric grease often makes more problems that it solves, if you use to much of it...
9Back to top Go down   Oil Light Empty Re: Oil Light on Fri Dec 13, 2013 6:43 pm
klamityboy
klamityboy
Thanks Bikerboy and Inge. Will clean the sensor and contact and will monitor.
Klamityboy
1991 K75RT-P
Market: Europe
Type: 0565
E-Code: K569
10Back to top Go down   Oil Light Empty Re: Oil Light on Fri Dec 13, 2013 7:44 pm
Salting the roads can cause problems like this as the salt causes a connection if it isnt cleaned off or gets under the rubber cap.
11Back to top Go down   Oil Light Empty Re: Oil Light on Fri Dec 13, 2013 8:26 pm
klamityboy
klamityboy
@RicK G wrote:Salting the roads can cause problems like this as the salt causes a connection if it isnt cleaned off or gets under the rubber cap.
The roads have been sprayed with brine recently as temperatures approach freezing.
Klamityboy
1991 K75RT-P
Market: Europe
Type: 0565
E-Code: K569
