1Back to top Go down   Swing Arm grease retainer - HELP Empty Swing Arm grease retainer - HELP on Tue Dec 17, 2013 2:41 pm
spinedoc
spinedoc
Hello all - I need help.
 In the process of removing the swing arm on my 1985 K100rs, I popped a hole in the grease retainer. I figured it would be easy to just pop the old one out and go to the dealer for a new one. No such luck. Does anyone know of a fix or swap for this part without buying a used swing arm off eBay?
Thanks in advance for any help.
I once took a train, but they made me put it back.
2Back to top Go down   Swing Arm grease retainer - HELP Empty Re: Swing Arm grease retainer - HELP on Tue Dec 17, 2013 2:49 pm
What's a "grease retainer?"  If you're referring to the rubber boot at the front of the swing arm then it is part 33171454552 and still available for about $20.
3Back to top Go down   Swing Arm grease retainer - HELP Empty Re: Swing Arm grease retainer - HELP on Tue Dec 17, 2013 3:44 pm
Spinedoc,
 If you mean the thin plate under the inner bearing, then you could simply cut a circle of tin plate (or even a drinks can) and use that.
 I have seen swing arms with and without that shield, so I don't think it would be a problem if that shield had a hole in it.
4Back to top Go down   Swing Arm grease retainer - HELP Empty Re: Swing Arm grease retainer - HELP on Tue Dec 17, 2013 6:58 pm
klamityboy
klamityboy
Do you mean #4 in this?
Swing Arm grease retainer - HELP Rear_s10
Klamityboy
1991 K75RT-P
Model Description: K 75RT
Market: Europe
Type: 0565
E-Code: K569
Engine: 3_ZYL - 0,70l (55kW)
Transmission: Manual
Body Color: Polizeiweiss
Production Date: 30.08.1990
5Back to top Go down   Swing Arm grease retainer - HELP Empty Re: Swing Arm grease retainer - HELP on Tue Dec 17, 2013 7:15 pm
I removed that thin plate on both Ks when the bearing was replaced and have not had any problems by not having it there.
I had water ingress from the outside on one bearing but nothing from the back of it.
I regrease the bearings when I do the splines which is at each tyre change.
6Back to top Go down   Swing Arm grease retainer - HELP Empty Re: Swing Arm grease retainer - HELP on Tue Dec 17, 2013 7:39 pm
spinedoc
spinedoc
so it is not #4 in the picture - I think that picture is for a different year.
this is the one I mangled trying to remove after I put a nickel sized hole in it.
Swing Arm grease retainer - HELP 20131212Swing Arm grease retainer - HELP 20131213
the one on the right is the good side
7Back to top Go down   Swing Arm grease retainer - HELP Empty Re: Swing Arm grease retainer - HELP on Tue Dec 17, 2013 7:50 pm
Thats the ones I was refering to I had to butcher them to get the cup out and didn't replace them just put loads of grease around the back of them.
8Back to top Go down   Swing Arm grease retainer - HELP Empty Re: Swing Arm grease retainer - HELP on Tue Dec 17, 2013 7:58 pm
klamityboy
klamityboy
So would it be #6?
Klamityboy
1991 K75RT-P
Market: Europe
Type: 0565
E-Code: K569
9Back to top Go down   Swing Arm grease retainer - HELP Empty Re: Swing Arm grease retainer - HELP on Tue Dec 17, 2013 8:02 pm
spinedoc
spinedoc
#6 is the actual bearing
10Back to top Go down   Swing Arm grease retainer - HELP Empty Re: Swing Arm grease retainer - HELP on Tue Dec 17, 2013 8:05 pm
spinedoc
spinedoc
Thanks Rick G
I will just yank out the old stuff and pack it real good, I will probably place a piece of tin over the gap to try to retain some grease near the bearing over time.
11Back to top Go down   Swing Arm grease retainer - HELP Empty Re: Swing Arm grease retainer - HELP on Tue Dec 17, 2013 8:13 pm
I think that what Paul suggested would be a good thing.
Apparently a very special tool is needed to get them out intact. I have a slide hammer with an expanding claw but could not get it to work on such a small bearing so out came the butchers block.
12Back to top Go down   Swing Arm grease retainer - HELP Empty Re: Swing Arm grease retainer - HELP on Tue Dec 17, 2013 8:29 pm
klamityboy
klamityboy
Ah so another case of a part not shown on the microfiche. Apologies for not being very helpful.  Very Happy
Klamityboy
1991 K75RT-P
Market: Europe
Type: 0565
E-Code: K569
13Back to top Go down   Swing Arm grease retainer - HELP Empty Re: Swing Arm grease retainer - HELP on Tue Dec 17, 2013 9:21 pm
orforester
orforester
Might be crazy, but I did the same thing, popped a hole in that thin plate behind bearing.  I took the seal off a peanut butter jar, it is alu and used grease to hold it in, sealing the hole up?  Call me hillbilly, yep I am.
89 K 100 RS se
85 K 100 RT
14Back to top Go down   Swing Arm grease retainer - HELP Empty Re: Swing Arm grease retainer - HELP on Wed Dec 18, 2013 8:19 am
I used heat to get the race out of the arm on the K100 when I replaced bearings.
Once the race is out you'll see it's just a thin metal cap type thing.
My R1100 has a similar swingarm/bearing setup but doesn't have those caps installed.
15Back to top Go down   Swing Arm grease retainer - HELP Empty Re: Swing Arm grease retainer - HELP on Wed Dec 18, 2013 9:27 am
the.postman
Measure the diameter and get yourself a core plug.
Many sizes available, and cheap as chips.
You can pick them up from any auction site (fleabay)
Tap it in gently.
Its only to keep the crap out.
Swing Arm grease retainer - HELP Core_p10
1984 srx 600
1986 cbr1000f/h
16Back to top Go down   Swing Arm grease retainer - HELP Empty Re: Swing Arm grease retainer - HELP on Wed Jan 15, 2014 4:09 pm
@the.postman wrote:Measure the diameter and get yourself a core plug.
Tap it in gently.
 Core plugs would be way to thick, unless you need to space the bearing.
I used the same method as Robin , heat gun for about 3 minutes then gave the  swing arm a good bump on a piece of timber, the race and rear thin tin plate grease retainer just came out. Very easy using the heat gun , no need for special bearing puller tool.
