1Back to top Go down   Bake warning light Empty Bake warning light on Thu Feb 13, 2014 4:26 am
Bigsax
Bigsax
I have just swapped out all my light bulbs (except headlight) to LED and they look and work sensational. Problem though. The brake warning light on the instruments stays on. Regular bulbs must complete a circuit that LED do not. Any suggestions?
Bake warning light Brick110
I stole this image, let me know if you want it back.
2Back to top Go down   Bake warning light Empty Re: Bake warning light on Thu Feb 13, 2014 4:32 am
Cleverbee
Cleverbee
No idea why, but sounds like you've sorted your own problem, would the cluster look odd if you retained the filament bulb for the brake warning light.....?
3Back to top Go down   Bake warning light Empty Re: Bake warning light on Thu Feb 13, 2014 4:45 am
xpc316e
xpc316e
Check out this guy's excellent advice on LED bulbs and the BMU:
http://classickbikes.com/ckb.tech/0.ckb.tech.files/bmu/bmu.htm
His whole site is a mine of great information.
4Back to top Go down   Bake warning light Empty Re: Bake warning light on Thu Feb 13, 2014 4:48 am
Bigsax
Bigsax
Thanks Cleverbee
I was hoping to hold that option for later. It is such a pain to get at I was hoping someone might suggest something easier. like cutting a wire or something
5Back to top Go down   Bake warning light Empty Re: Bake warning light on Thu Feb 13, 2014 4:51 am
Bigsax
Bigsax
@xpc316e wrote:Check out this guy's excellent advice on LED bulbs and the BMU:
 Brilliant!
Thanks xpc316e
6Back to top Go down   Bake warning light Empty Re: Bake warning light on Thu Feb 13, 2014 5:13 am
Does the bake warning light tell you when the scones are ready?
'87 K100RS/HRD sidecar (1100 motor)  sc25
'92 K100RS-16v (Paint it Black)
Bake warning light K-dogs10
7Back to top Go down   Bake warning light Empty Re: Bake warning light on Thu Feb 13, 2014 5:17 am
It's when the airfilter housing is hot enough to put the scones in.
8Back to top Go down   Bake warning light Empty Re: Bake warning light on Thu Feb 13, 2014 10:55 am
At first I thought it meant Bakelite, until I read the thread...
Scones are ready at my house!
1977 R75/7-R100 grey, '87 K100RS red, '93 K11-K12 aka 'Big Block' black, '96 K1100RS black, '98 K1200RS red, '09 K1300GT red, & 2013 R1200RT-Polizia black & white.
9Back to top Go down   Bake warning light Empty Re: Bake warning light on Thu Feb 13, 2014 12:59 pm
klamityboy
klamityboy
@Bigsax wrote:I have just swapped out all my light bulbs (except headlight) to LED and they look and work sensational. Problem though. The brake warning light on the instruments stays on. Regular bulbs must complete a circuit that LED do not. Any suggestions?
I have upgraded to all LED including the Brake Monitor bulb. Mine briefly lights when the brake is pressed. Something along the lines of a filament bulb cannot respond quickly enough to the small pulse of electricity but the LED can. With regards to your problem, is it possible that the brake light bulb may have failed or the Bulb Monitoring Unit? Don't forget to depress the brake pedal and handle. As already stated in other posts, my electrical expertise is limited at best and should probably be confined to changing the AA batteries in the TV remote. I am however a frequent victim of Murphy's law. If this was me the brake bulb will have burned out exactly when I made a modification, thus my inclination to starting with the simplest and cheapest option first.
Good luck with the baking!!
Klamityboy
1991 K75RT-P
Model Description: K 75RT
Market: Europe
Type: 0565
E-Code: K569
Engine: 3_ZYL - 0,70l (55kW)
Transmission: Manual
Body Color: Polizeiweiss
Production Date: 30.08.1990
10Back to top Go down   Bake warning light Empty Re: Bake warning light on Thu Feb 13, 2014 2:54 pm
tgolden
tgolden
Is it possible to switch to LEDs and keep the BMU intact and functional?
Everything I've read to date indicates that with LEDs, the BMU must be disabled.
Regards
11Back to top Go down   Bake warning light Empty Re: Bake warning light on Thu Feb 13, 2014 3:03 pm
klamityboy
klamityboy
@tgolden wrote:Is it possible to switch to LEDs and keep the BMU intact and functional?
Regards
Works in mine. I just replaced the filament bulb with an LED and made no other changes. The only quirk is that the Bulb Monitor light will briefly and faintly flash when the brakes are applied. Only an issue at night and I find it oddly reassuring to know that the brake light has come on. Can't even see it during the day. There has been a suggestion, probably on Duck's page, that adding a resistor makes this quirk go away.
Klamityboy
1991 K75RT-P
Market: Europe
Type: 0565
E-Code: K569
12Back to top Go down   Bake warning light Empty Re: Bake warning light on Thu Feb 13, 2014 4:25 pm
Brad-Man
Brad-Man
I personally don't need a warning light to know I'm baking...
13Back to top Go down   Bake warning light Empty Re: Bake warning light on Thu Feb 13, 2014 6:32 pm
Bigsax
Bigsax
I have removed the BMU and shorted the wires in the electronics box as per the link earlier in this thread.
All good. I will just manually check my lighting system. LED's should last for thousands of hours anyway.
