The right indicator switch on my 16v RS works but does not return.  Either the spring is missing or rusted from being stored outdoors by the PO.
I'm just looking for a rough switch block as a donor to disassemble for bits to repair mine.  8 valve or 16 valve is not important
'87 K100RS/HRD sidecar (1100 motor)  sc25
'92 K100RS-16v (Paint it Black)
Right hand handlebar switchblock - condition not important. K-dogs10
The switch cluster may simply need disassembling and cleaning.  This guide illustrates the disassembly/cleaning/reassembly procedure. It will save you money having to buy a new switch assembly.
I've disassembled and cleaned them before.  I'm not intending to buy a new one.
The spring in the indicator switch is either missing or so rusty that it doesn't work. I was asking if someone had a broken/damaged one they didn't need as i'm only looking for that spring.
...and I sent you a pm on Facebook.
