1Back to top Go down    Custom Radiator Grille on Tue Feb 25, 2014 11:55 pm
Bigsax
I recently removed my lower fairings and have been a little worried about the unprotected radiator, so I made a shield for it.
I got some stainless mesh and cut it 260mm x 350mm.
I then put some pinch trim around the edges and just for extra buffering I put some rubber grommet buttons on it. Actually not needed as it turned out.
I fixed it to the radiator with some cable ties.
I tried to keep the cable ties out of sight by tying at the bottom not the sides.
I am pretty happy with the results
I have enough material left for one more about $20. PM me if you are interested.
I stole this image, let me know if you want it back.
2Back to top Go down    Re: Custom Radiator Grille on Wed Feb 26, 2014 12:30 am
Being an SSS (slut for stainless steel) myself, I freely give this the ofishul duck seal of approval. Very nice!
Some other options in the SS arena are:
Perforated SS:
"Expanded metal" SS:
91 K75S
3Back to top Go down    Re: Custom Radiator Grille on Wed Feb 26, 2014 2:20 am
looking good there big ...similar is on my list
perhaps even a black forum logo painted on ???
4Back to top Go down    Custom Radiator Grille on Wed Feb 26, 2014 6:46 am
That;s pretty nifty bigsax, well done.
Suzuki V Strom 650DL 2011. Gasp, chain driven.
5Back to top Go down    Re: Custom Radiator Grille on Wed Feb 26, 2014 7:02 am
Yeas ago when I repainted the K75, I replaced both grills with something similar to the original grills. It took me a long time to find a grill close to the original one.Twisted Evil.
1986 k75, 1985 K100rt, 1985 K100rt/EML sidecar.
6Back to top Go down    Re: Custom Radiator Grille on Wed Nov 05, 2014 4:00 am
I recently removed the lower fairings on my RT and they're not going back on because they've had it. The top is not much better. The exposed radiator always worried me and after a recent trip (around 2400klm) I noticed a small dent in the fins from a stone. So I had to get a grill back on there asap.
I removed the grill from the original radiator cowling and cut it down to 335mm(W) x 240mm(H) keeping the original orientation.
Original grill
Cut down to 335mm x 240mm
Cut a recess of 5mm at the bottom of each side as shown. This allows the grill to hang down over the bottom edge for fixing. The top doesn't need this because its already scolloped.
Slide the grill into one side then flex to fit the other side. I secured this with a couple of self-threading tech screw. Just a temporary fix as I'll be doing a few mods and a bit of sprucing up next year. I'll eventually sandblast and paint the grill when I do the tank next year, fix some trim to the bottom edge and replace the screws with a couple of bolts.
The recess at the bottom when fitted.
I thought this would be just a temporary solution but I'm liking the way it looks. Some s/s mesh would look pretty good too.
1988 K100RT VIN No. 0094680
1989 K100RT VIN No. 0097367 (naked)
1996 K1100RS VIN No. 0451808
Fuel: 95 Octane
Engine Oil:Nulon Full Synthetic 15W50
Gear Box Oil: Nulon Synthetic 75W90
7Back to top Go down    Re: Custom Radiator Grille on Wed Nov 05, 2014 4:21 am
Well done Kaptain. It looks good.
Now Murphy's Law will rear its ugly head when a stone goes through the hole in the mesh. No where else, just the hole!
Last edited by blaKey on Wed Nov 05, 2014 5:28 am; edited 1 time in total (Reason for editing : editing? We don't need no steenking editing!)
K100RT 1987 (now nekkid with red bits)
Remember Rule No. 6
8Back to top Go down    Re: Custom Radiator Grille on Wed Nov 05, 2014 4:30 am
Kaptain Holister wrote:I recently removed the lower fairings on my RT and they're not going back on because they've had it. The top is not much better. The exposed radiator always worried me and after a recent trip (around 2400klm) I noticed a small dent in the fins from a stone. So I had to get a grill back on there asap.
Original grill
yes s/.s mesh sounds great
or you could extend the mudguard on the front down a little with a rubber flap and stop those nasty stones ever getting into the grill at all ...but there is always the unexpected bird strike or similar ...good luck !
9Back to top Go down    Re: Custom Radiator Grille on Wed Nov 05, 2014 9:40 pm
LFB has a woven stainless steel mesh on it, but I'd actually advise against using the woven stuff because it needs securing in additional places to stop the weave from moving and the corners will try an early departure from this mortal coil. Go for punched stainless steel instead - it's a bit more expensive but far easier to mount.
10Back to top Go down    Re: Custom Radiator Grille on Wed Nov 05, 2014 10:04 pm
@blaKey wrote:Well done Kaptain. It looks good.
Yep. Murphy knows me well Laughing When I secure a bit of trim to the bottom edge I thought I'd put a centre piece up the middle to provide a little support and cover the hole. Or a new piece of mesh. Might see what ss looks like.
Fuel: 95 Octane
11Back to top Go down    Re: Custom Radiator Grille on Wed Nov 05, 2014 11:21 pm
I made a custom grille for my orange bike a couple of years ago...check a journey begins...don't know how to link it to this post.
1983 K100basic vin 0003960 colour red
1987 K100RT vin 0094685 colour, orange peel, sorry, pearl
12Back to top Go down    Re: Custom Radiator Grille on Thu Nov 06, 2014 7:34 am
Nigel a bm logo off the pannier would fit over that hole and look smick all ya have to do is find one.
Keith - 1987 K75c with r100rt replica fairing and half of a 1984 K100rt
13Back to top Go down    Re: Custom Radiator Grille on Thu Nov 06, 2014 5:30 pm
Be made
mmm . . .I did mine during the build. Same sort of deal really, just using Aluminium channel for the frame and SS screen
Started out plain square
and ended up with a BMW Kidney painted on:
Not sure which looks better. When I look back to how it started it looks a lot cleaner unpainted but then peoples say it does not look like it fits with the rest of the bike so it got painted
14Back to top Go down    Re: Custom Radiator Grille on Thu Nov 06, 2014 7:34 pm
@K75cster wrote:Nigel a bm logo off the pannier would fit over that hole and look smick all ya have to do is find one.
I like that. A BM keychain fob would be just slightly bigger and easier to find. Thanks for the idea.
Fuel: 95 Octane
15Back to top Go down    Re: Custom Radiator Grille on Thu Nov 06, 2014 7:47 pm
@Be made wrote:.....
Be made, when I first saw yours I thought I'd do mine the same and I think it looks better painted.
I really like what you've done to the air intake. Looks smick from what I can see. Care to post a good closeup of that.
Fuel: 95 Octane
16Back to top Go down    Re: Custom Radiator Grille on Thu Nov 06, 2014 8:29 pm
Be made
Kaptain Holister wrote:I really like what you've done to the air intake. Looks smick from what I can see. Care to post a good closeup of that.
The Air intake has changed up since that photo was taken and now looks like all the rest (black, no grill) but I have the other one for when I get bored with the look
Very simple to do.
I just used a Hot melt glue gun, ran a bead around the edge first, pressed the grill in (tight fit) then ran the gun around the outside edge and painted
After I fitted the spot lamps the grill on the intake was barely noticable but I assume it would stop some major bugs prior to the filter doing the same thing
17Back to top Go down    Re: Custom Radiator Grille on Thu Nov 06, 2014 8:33 pm
Be made
ainsjac wrote:I made a custom grille for my orange bike a couple of years ago...check a journey begins...don't know how to link it to this post.
Find the post and right click on it the link at the top of it, select copy link location and then paste it in your new post;
http://www.k100-forum.com/t4086p200-the-journey-begins#49930
18Back to top Go down    Re: Custom Radiator Grille on Thu Nov 06, 2014 9:21 pm
Many thanks
