You can now order the forum stickers. Login and go to the "members only" forum. This is not available for guests yet....
1Back to top Go down    Rear drive oil seal on Thu Feb 27, 2014 4:17 am
JGT
I am right in thinking that the rear drive oil seal and 'O' ring can be replaced without removing the whole bevel drive assembly from the bike? John
1987 K75s  1969 Bultaco Matador
2Back to top Go down    Re: Rear drive oil seal on Thu Feb 27, 2014 4:24 am
tgolden
It might be possible, but I think it would be easier if you did. If your seal and o-ring need to be replaced, it might be prudent to do a complete disassembly, cleaning and inspection. Check out the video below.
1985 K100RS USA Model WB1051300F0042533 - Original Owner
Delivery: 04/85 - Motorradhaus Ebert, Höchberg, Deutschland
3Back to top Go down    Re: Rear drive oil seal on Thu Feb 27, 2014 6:28 am
MikeP
Yes. It can. I've done it more than once.
1992 K1
4Back to top Go down    Re: Rear drive oil seal on Thu Feb 27, 2014 6:56 am
JGT
Thanks, Will attack it this week end. John
5Back to top Go down    Re: Rear drive oil seal on Thu Feb 27, 2014 7:10 am
Hi John,
If the cover is tight, this might help:
http://www.k100-forum.com/t3936-dismantling-the-bevel-box
Good luck,
6Back to top Go down    Re: Rear drive oil seal on Sun Mar 02, 2014 3:35 am
JGT
Job done. It needed heat an a few taps on the caliper mounting. My rear drive did not have the 10 mm taped hole, 1994 bike, perhaps deleted as a cost saving. 88,000 miles, is that the life expectancy for the seal? John
7Back to top Go down    Re: Rear drive oil seal on Sun Mar 02, 2014 7:36 am
MikeP
The Paralever cases don't have the tapped thread.
1992 K1
8Back to top Go down    Re: Rear drive oil seal on Sun Mar 02, 2014 6:47 pm
JGT
My K75 isn't paralever.
9Back to top Go down    Re: Rear drive oil seal on Sun Mar 02, 2014 6:50 pm
MikeP
Just saying that at some stage they obviously stopped tapping one thread and as the Paralever models don't have it and the cover plates are the same, it was probably at that time that it was deleted.
1992 K1
