1Back to top Go down   Oil Caddy Build Empty Oil Caddy Build on Thu Feb 27, 2014 12:08 pm
Shoganai
Shoganai
Well the reason I couldn't find the pictures of this mini project was that in my rush to get the bike ready, I didn't take any.
Here is the oil caddy I built.
I bought two of these. Powermadd Polaris GEN II Chassis Oil Caddy.
(Well the actual ones I bought did not have that large side plate and did have the black bungee strap to hold the oil in the caddy.)
Oil Caddy Build Oil%20Caddy-XL
This is the exact one I bought. PowerMadd 74805 Spare Oil Storage for Polaris Gen II
Oil Caddy Build Oil%20Caddy%203
And a bar of 1" x 4" aluminum stock.
I mount it in place of the right rear foot peg and was able to use the OEM bolt. I put it there for two reasons. One, it was closest to the oil fill on the K11 and two, I didn't give up any premium storage location.
Oil Caddy Build DSCF1149-XL
Oil Caddy Build DSCF1149%20-%201-X2
Oil Caddy Build DSCF1152%20-%201-X2
Oil Caddy Build DSCF1151-X2
Oil Caddy Build DSCF1152-X2
Oil Caddy Build DSCF1154-X2
Oil Caddy Build Oil%20Caddy%202-XL
Oil Caddy Build DSCF1149%20-%202-XL
It worked perfectly!
2Back to top Go down   Oil Caddy Build Empty Re: Oil Caddy Build on Thu Feb 27, 2014 12:33 pm
Yer crazy!
You might want to consider using short bolts for F.  If you use one that's too long the rear one might scratch the FD.
3Back to top Go down   Oil Caddy Build Empty Re: Oil Caddy Build on Thu Feb 27, 2014 1:06 pm
Shoganai
Shoganai
Scratch the FD!?  Oil Caddy Build 44271
4Back to top Go down   Oil Caddy Build Empty Re: Oil Caddy Build on Thu Feb 27, 2014 1:36 pm
I meant swing arm.
5Back to top Go down   Oil Caddy Build Empty Re: Oil Caddy Build on Thu Feb 27, 2014 1:41 pm
Shoganai
Shoganai
I knew what you meant, I was just giving you a hard time sweetie.
(F) are the OEM bolts to my knowledge and nothing moves or flexes with that assembly.
I could go with shorter ones just to clean it up though.
