1Back to top Go down   Rough Idle Empty Rough Idle on Fri Apr 11, 2014 12:49 pm
Finnigan
Finnigan
Hey Everyone
Just got a 1990 k100, first bike and I'm very excited.  Got it for a steal because of high miles but looks mechanically sound.
The question I have is about idling at a light.  It sounds like the engine struggles to stay around 1k RPM and sounds like it might stall.  It hasn't so far but I'm wondering if theres an adjustment I can make.
Clean filters, no clogs, pulls hard through rev range and gets great mileage so far.  There is 1 or 2 SMALL cracks in one of the intake boots but I doubt it goes all the way through.  Thinking of putting some RTV on them to see if it improves.
Very new to bikes and BMWs so any info is appreciated
Thanks!
Rough Idle 2]<img src=" />
2Back to top Go down   Rough Idle Empty Re: Rough Idle on Fri Apr 11, 2014 1:06 pm
This is probably your issue.  Easy to test.  At idle spray some starter fluid around the boots between the throttle bodies and the cylinder head. If the idle increases then they're leaking and need to be replaced.
When these cracks are starting, the bike will idle roughly but run fine at higher revs because the vacuum temporarily seals them.
The other thing you can do to smooth out a K is sync the throttle bodies.
http://classickbikes.com/ckb.tech/0.ckb.tech.files/tbsync/tbsync.htm
3Back to top Go down   Rough Idle Empty Re: Rough Idle on Fri Apr 11, 2014 1:43 pm
Finnigan
Finnigan
Thats perfect thanks for the website
4Back to top Go down   Rough Idle Empty Re: Rough Idle on Fri Apr 11, 2014 5:56 pm
Also check the crankcase vent. hose, S shaped, at the rear end of the plenum chamber.
5Back to top Go down   Rough Idle Empty Re: Rough Idle on Fri Apr 11, 2014 7:02 pm
Comberjohn
Comberjohn
Make sure the rubber blanking caps are on the vacuum take off points on the injectors. Or they may be cracked.
Check the rubber hose on the rearmost take off too.
I once put one of the blanking caps on to an adjuster screw on the TB's by mistake and caused the problem you describe.
I know that at least one other person on the forum has had the same senior moment.
Life is not a rehearsal.
2010 VFR 1200F DCT
2010 R1200GS(gone)
1986 K100 Silver(gone)
2012 K1600GT(gone)
1984 K100 Red(gone)
6Back to top Go down   Rough Idle Empty Re: Rough Idle on Fri Apr 11, 2014 7:31 pm
Finnigan
Finnigan
Haha good idea, i think one might be missing...?
Any suggestions for a temporary plug while i order some parts?
7Back to top Go down   Rough Idle Empty Re: Rough Idle on Fri Apr 11, 2014 7:37 pm
Comberjohn
Comberjohn
Chewing gum? Insulating tape?
As long as it stops air getting in.
Just had a thought. Remember, there are only 3 caps. The rear take off should be covered by a rubber pipe.
2010 VFR 1200F DCT
2010 R1200GS(gone)
2012 K1600GT(gone)
1984 K100 Red(gone)
8Back to top Go down   Rough Idle Empty Re: Rough Idle on Fri Apr 11, 2014 7:41 pm
A short piece of soft rubber hose with the correct id., bend it 180 degr., add a zip tie.
9Back to top Go down   Rough Idle Empty Rough Idle on Fri Apr 11, 2014 8:02 pm
Thanks for reminding the whole world about my senility Comberjohn. Easy mistake to make really. WEAR YOUR GLASSES.
10Back to top Go down   Rough Idle Empty Re: Rough Idle on Fri Apr 11, 2014 8:21 pm
Rough Idle 34611810
11Back to top Go down   Rough Idle Empty Re: Rough Idle on Fri Apr 11, 2014 8:25 pm
Comberjohn
Comberjohn
So that's who it was!
Couldn't remember. Another symptom of impending brain fade.
2010 VFR 1200F DCT
2010 R1200GS(gone)
2012 K1600GT(gone)
1984 K100 Red(gone)
12Back to top Go down   Rough Idle Empty Re: Rough Idle on Fri Apr 11, 2014 9:19 pm
You are free to speak John he already fessed up.
13Back to top Go down   Rough Idle Empty Re: Rough Idle on Fri Apr 11, 2014 9:24 pm
Finnigan, what sort of 1990 K100 is the bike. It makes quite a difference sometimes, the RS had a 16 valve engine and the LT and Naked had the 8 valve in that year.
Also we find that putting the model and year etc in the signature line helps because you don't need to tell us (see Comberjohn's brainfade post) every time which it is.
14Back to top Go down   Rough Idle Empty Re: Rough Idle on Sat Apr 12, 2014 5:21 am
Comberjohn
Comberjohn
Fess up?? It was my confession that made RT come clean.
Anyone else wanna get it off their chest.
2010 VFR 1200F DCT
2010 R1200GS(gone)
2012 K1600GT(gone)
1984 K100 Red(gone)
15Back to top Go down   Rough Idle Empty Re: Rough Idle on Sat Apr 12, 2014 5:26 am
Oh maybe I better not laugh too much Embarassed
16Back to top Go down   Rough Idle Empty rough idle on Sat Apr 12, 2014 7:14 pm
kartooo
kartooo
my newly aquired 85 k100rt has kept me busy. i did the clutch spline,driveshaft spline,eng diff fork and trans oil,brake fluid, cleaned every connector and ground, put some rancho gaitors on it. new crank vent hose, new clutch rod boot. synched the throttle bodies but never liked the ROUGH IDLE and hard cold start. changed the injector O rings and that helped. today i replaced the throttle body to head intake rubbers. i have a new bike !!!! the cracks on the old ones could not be seen until out, then if i flexed em i could see the mess. being old and brittle i don't think they seated well up against the head either. my gosh what difference in personality. well worth the time and effort. still a youngster with only 25k.
17Back to top Go down   Rough Idle Empty Re: Rough Idle on Sat Apr 12, 2014 8:55 pm
So now we have another happy customer.
Now off you go into those hills and have heaps of fun Very Happy
18Back to top Go down   Rough Idle Empty Re: Rough Idle on Sat Apr 12, 2014 9:49 pm
kartooo
kartooo
@RicK G wrote:So now we have another happy customer.
with only 25k  there are heaps of fun left in her....
85 k100rt current
04 vulcan 1500 classic sold
07 bonneville black sold
05 fjr1300 sold
04 r1150rt sold
91 k100lt sold
r80rt sold
85 K100 sold
19Back to top Go down   Rough Idle Empty Re: Rough Idle on Sat Apr 12, 2014 9:50 pm
 cheers  cheers  cheers
20Back to top Go down   Rough Idle Empty Re: Rough Idle on Mon Apr 14, 2014 12:32 pm
Finnigan
Finnigan
Got into throttle body syncing this weekend:  Found that one vacuum plug was missing, but hooked up my carb vacuum gauges anyway.  All of them seem to be off in one way or another and its impossible to get them all the same so this makes me think its an air leak on one or more boots.  Got it to idle smoother but not near perfect and it had a little trouble -even with chock on- when I first started her up this morning.  Ran to work great though.  Tomorrow I'll get some starter fluid and RTV for a patch job while I save up enough money to get the 50/each rubber boots
1990 k100LT
21Back to top Go down   Rough Idle Empty Re: Rough Idle on Mon Apr 14, 2014 1:32 pm
Also look at the engine breather hose (tucked up above the TPS between the airbox and the TBs) as it can be cracked causing no end of idle dramas. Another thing to look at is the engine oil filler plug's o-ring. While the engine is idling remove that plug and see what happens. Lightly spray a not-too volatile propellant at the intake boots above and below the TBs to see if the idle RPM changes. This indicates an air leak. The entire airbox system must be tight and leak-free.
BTW, you can only 'sync' the TBs at idle, not running RPM without some expensive, complex kit. Sage advice is to not touch the adjustment screws in the linkage between the TBs.
1987 K100RS, '89 K100 w/K1100RS engine, '93 Framed K11/K12 engine 'Big Block', '96 K1100RS, '09 K1300GT, '13 R1200RT-P, '95 R100 Mystic & '77 R75/7.
22Back to top Go down   Rough Idle Empty Re: Rough Idle on Mon Apr 14, 2014 2:15 pm
don't forget the injector seals finnigan
also a source for air leaks
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%ORough Idle Au-log10
"redframe" rs "bitsa"  with many contributions from the k100 community ,,with many thanks
23Back to top Go down   Rough Idle Empty Re: Rough Idle on Mon Apr 14, 2014 3:07 pm
Comberjohn
Comberjohn
I couldn't sync my injectors until I checked the valve clearances and replaced three shims.
No problems syncing afterwards.
Might be worth checking if you don't find any air leaks.
2010 VFR 1200F DCT
2010 R1200GS(gone)
2012 K1600GT(gone)
1984 K100 Red(gone)
24Back to top Go down   Rough Idle Empty Re: Rough Idle on Mon Apr 14, 2014 3:43 pm
@Comberjohn wrote:I couldn't sync my injectors...
They're easy to juggle though you must have them out of the fuel rail.
 Laughing
Time for a Guinness, I'd say.
25Back to top Go down   Rough Idle Empty Re: Rough Idle on Mon Apr 14, 2014 3:46 pm
kartooo
kartooo
replacing the injector O rings did make my idle nicer but no real progress until i replaced the throttle body to head boots. they look good to the eye but once you actually take them out and flex them the cracks really show them selves. carb or brake cleaner with the little tube attached will tell you whats going on.
