1 FITTING OF TEMP & OIL PRESSURE GAUGES Tue 12 Jul 2011, 19:59
bushyintas
Have just finnished fitting aditional gauges (temp & oil pressure),
temp gauge sender fitted perfectly in to water pump drain plug,
to fit the oil pressure line I made an adaptor to fit the oil gallery grub screw in the front of the head, this runs along side of the wiring to the original oil sensor, up to behind the radiator where the new gauge sensor is attached to the lower fairing bracket. in this possition the pressure is read after the filter so if any problems occur in the filter it is shown on the gauge.
Let me know what you think...
Regards Bushy
Regards Bushy
