1Back to top Go down   Luggage rack - horizontal type- EU Empty Luggage rack - horizontal type- EU on Fri Apr 18, 2014 8:44 am
I need a new top box for will upcoming trip to France. I need one of the horizontal carrier rack ( as opposed to sloping original) if any one has one kicking around pm my with a price please.
Will
Luggage rack - horizontal type- EU Ir-log11 88....May contain nuts!Luggage rack - horizontal type- EU Ir-log11
2Back to top Go down   Luggage rack - horizontal type- EU Empty Re: Luggage rack - horizontal type- EU on Fri Apr 18, 2014 9:09 am
3Back to top Go down   Luggage rack - horizontal type- EU Empty Re: Luggage rack - horizontal type- EU on Fri Apr 18, 2014 10:58 am
Givi E181 is what you need.
4Back to top Go down   Luggage rack - horizontal type- EU Empty Givi's topcase carrier rack on Sun Apr 20, 2014 12:21 pm
ffbikersa
ffbikersa
88KE wrote:I need a new top box for will upcoming trip to France. I need one of the horizontal carrier rack ( as opposed to sloping original) if any one has one kicking around pm my with a price please.
Will
On my K 100 I installed Givi's Top case carrier such as this one, replacing the original (everything you need - screws, bolts etc. - is included in the set), It costed me less, though - just € 69,90. So Google for a cheaper offer:
http://www.motorcycleparts-hornig.com/BMW-elderly-model-since-1969/Seats-Trunks-and-Bags/Top-case-mounting.html
Then, because the design of Givi's own top cases does not fit well with BMW original side cases (AND cost of Givi is bit too high for my pocket), I bought and installed "Moto Detail" case from one of three huge German motorcycle shop's chains, Detlev Louis. It's an earlier model similar to what they now offer:
http://www.louis.de/_30dab61315ffa97a1ba748d5f6810aa19b/index.php?topic=artnr_gr&artnr_gr=10025920
Tarik
5Back to top Go down   Luggage rack - horizontal type- EU Empty Here's cheaper: on Sun Apr 20, 2014 12:23 pm
ffbikersa
ffbikersa
Will
http://www.motobuykers.co.uk/store/motorbike-accessories/luggage-accessories/hard-cases-givi_top-case-rack-givi/trunk-adaptor-kit-monokey-c-m5-bmw-k100-1000-90-k-rs-1100-k75-750_GIVIE181.html
I suppose you can ask the GIVI dealer in your country too?
6Back to top Go down   Luggage rack - horizontal type- EU Empty Pics too on Sun Apr 20, 2014 12:37 pm
ffbikersa
ffbikersa
Will
See how it looks:
Luggage rack - horizontal type- EU Top_ca10
Luggage rack - horizontal type- EU Top_ca11
7Back to top Go down   Luggage rack - horizontal type- EU Empty Re: Luggage rack - horizontal type- EU on Sun Apr 20, 2014 8:33 pm
I do hope you have some reinforcing under the tail section because I am in the process of fixing my wife's tail section because it got busted up from the stress of a top box.  It tore the fibreglass apart and we had to use gaffa tape to keep the box from falling off the bike.
8Back to top Go down   Luggage rack - horizontal type- EU Empty Re: Luggage rack - horizontal type- EU on Sun Apr 20, 2014 8:46 pm
It was also a problem with the 50 litre OEM box on the 100LT which was bolted
directly to the duck tail, but it also stretched far behind the tail
....wrong weight distribution....it didn't stay long on the market.
9Back to top Go down   Luggage rack - horizontal type- EU Empty No reinforcing yet on Mon Apr 21, 2014 5:25 am
ffbikersa
ffbikersa
@RicK G wrote:I do hope you have some reinforcing under the tail section because I am in the process of fixing my wife's tail section because it got busted up from the stress of a top box.  It tore the fibreglass apart and we had to use gaffa tape to keep the box from falling off the bike.
Well to be honest I did not install any, because the way how this rack was being attached seemed quite firm to me, and that the forces are well distributed. I also try never to carry anything too heavy in the top case - my laptop being the heaviest item.
10Back to top Go down   Luggage rack - horizontal type- EU Empty Re: Luggage rack - horizontal type- EU on Mon Apr 21, 2014 5:55 am
One thing which has not been mentioned with regard to top boxes is the stress induced by the airflow.  It will be more prevalent on the forward outside front surface of the box and will act as a mini airbrake interfering with the streamlining of the airflow over the bike.  Although not an expert in aerodynamics, there will be a greater influence as compared to say the BMW OEM top box.
As I have only ever been on a couple of perfect road surfaces (racetracks), everything else has bumps and irregularities.  There will be further stress induced by the weight of the top box through the mounting points and as the bike bounces around on the road, the stresses all add up.  If anything is loosely packed inside the box on a bumpy or twisty road, resulting in weight movement, then this will compound the stresses as the directions change.  As the contact surface is relatively small through the four mounting points, I doubt there will be a perfect system to prevent stress fractures (cracks) for our bikes unless the duck tail is made of metal.
Always a compromise, so the bottom line is don't carry too much heavy crap inside.
I guess the Givis are popular because you can lock a helmet inside.  Personally I prefer the BMW OEM.
Just an opinion so feel free to disagree.
11Back to top Go down   Luggage rack - horizontal type- EU Empty Re: Luggage rack - horizontal type- EU on Mon Apr 21, 2014 7:44 am
Saying that to an Irishman....its a legitimate invitation to engage in 'lively debate'.
But very valid. I have a large top box, most essential to make sure everything is tightly fitted up and no play, load spreading washers inside the ducktail. Riding without the box on, even empty, has a very very noticeable difference.
12Back to top Go down   Luggage rack - horizontal type- EU Empty Just as good & cheaper on Mon Apr 21, 2014 8:29 am
ffbikersa
ffbikersa
@TacKler wrote:One thing which has not been mentioned with regard to top boxes is the stress induced by the airflow.  It will be more prevalent on the forward outside front surface of the box and will act as a mini airbrake interfering with the streamlining of the airflow over the bike.  Although not an expert in aerodynamics, there will be a greater influence as compared to say the BMW OEM top box.
Moto Detail from Louis are just as good when build quality is in question, you can lock a helmet (or two - see the pic), and cost much less for the same size...
Luggage rack - horizontal type- EU 10025920_740_ANW1_FR_05
13Back to top Go down   Luggage rack - horizontal type- EU Empty All that's there on Mon Apr 21, 2014 8:36 am
ffbikersa
ffbikersa
14Back to top Go down   Luggage rack - horizontal type- EU Empty Re: Luggage rack - horizontal type- EU on Mon Apr 21, 2014 9:07 am
My wife rarely carried much more than wet weather gear and handbag and kept the space to store her helmet when not riding.
Good luck I think you will need it.
