1Back to top Go down   Wiring question Empty Wiring question on Sun Apr 20, 2014 3:15 pm
brianpen
brianpen
Wiring question Dsc01118
Examining the wires under my tank, I noticed what first appeared to be exposed wire. On closer inspection it appears the black wire in this connector has some sort of shielding thing going on. As I peeled back the insulation a bit the exposed wire appears to be purposely wrapped around the others inside of the bundled insulation.
Before I wrap it back up (as it appears normal) I wanted to get an opinion on it.
2Back to top Go down   Wiring question Empty Re: Wiring question on Sun Apr 20, 2014 3:21 pm
This is the connector to the hall sensor, and the wires is shielded.
This connector have a rubber cap on the outside, which usually rots away after a few years.
3Back to top Go down   Wiring question Empty Re: Wiring question on Sun Apr 20, 2014 5:04 pm
brianpen
brianpen
Thanks Inge. The rubber boot was torn to bits. I'll wrap it up and move on.
4Back to top Go down   Wiring question Empty Re: Wiring question on Sun Apr 20, 2014 5:39 pm
Wiring question 112350  Some protection spray/liquid wouldn't hurt while you have the connector apart
...........use DeoxIT and you gonna end up in heaven...just search this forum.
