1Back to top Go down   speedo fault Empty speedo fault on Sat Apr 26, 2014 9:35 am
chris.edwards2
chris.edwards2
Hi, anyone know how to test the speedo feed on a K100. I had intermittent fault, then no speedo at all (for past year).
I do remember that tapping the instrument cluster did improve the intermittent fault so suspect feed is good. Are there any quick checks for known faults on the speedo electronics that may fix it or do i look for replacement?
2Back to top Go down   speedo fault Empty Re: speedo fault on Sat Apr 26, 2014 9:40 am
many post though out the forum chris
use that "search" feature
there is also a programme called "Karumba " that imitates the bike at speed to the electronics ....a cable from the earphone socket on a laptop injects into the speedo connector under the right hand side side cover
you have been through all the connectors and cleaned them up ...haven't you ?
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%Ospeedo fault Au-log10
3Back to top Go down   speedo fault Empty Re: speedo fault on Sat Apr 26, 2014 9:48 am
