1Back to top Go down   oil & coolant Empty oil & coolant Sat May 03, 2014 7:48 am
emmanuelfiadjoe
emmanuelfiadjoe
pls, in my country (ghana, west africa), the climate is really hot. which type of oils (engine, transmission & final drive) and coolant is the best for me to use?
Model: K 100 RS 83 (0502,0503,0513)
Series: K589 (k100, RS, RT, LT)
Production Month/Year: 07/1984
Region: Europe
VIN: 0018945
2Back to top Go down   oil & coolant Empty Re: oil & coolant Sat May 03, 2014 8:47 am
I would use the grades that BMW recommend in a synthetic which will give you a longer life between changes
Gearbox and final drive SAE80w-90 hypoid gear oil.
oil & coolant Page_214
3Back to top Go down   oil & coolant Empty synthetic? Sat May 03, 2014 10:14 am
emmanuelfiadjoe
emmanuelfiadjoe
how do you know an oil is synthetic? most of the oils i see in the market here don't have any label on them to indicate whether their synthetic or not.
Region: Europe
VIN: 0018945
4Back to top Go down   oil & coolant Empty Re: oil & coolant Sat May 03, 2014 1:24 pm
A synthetic oil also handles much higher temperatures, but if you can't get it .......
5Back to top Go down   oil & coolant Empty Re: oil & coolant Sat May 03, 2014 1:30 pm
If it doesn't say synthetic on it then it probably isn't.  If you can't get synthetic then I'd use Castrol GTX 20/50 if you  can find it.
6Back to top Go down   oil & coolant Empty shell helix ultra Sat May 03, 2014 2:33 pm
emmanuelfiadjoe
emmanuelfiadjoe
i'v found fully synthetic shell helix ultra 5w-40 for high performance engines. will that be ok for my engine?
Region: Europe
VIN: 0018945
7Back to top Go down   oil & coolant Empty Re: oil & coolant Sat May 03, 2014 2:42 pm
Yes it will. It will be better than a mineral in your hot climate. I use 5W40 full synthetic here in the south of France and it gets quite hot here in the summer.
8Back to top Go down   oil & coolant Empty Re: oil & coolant Sat May 03, 2014 3:04 pm
When I can't get Mobil 1 15-50 at Walmart (they're out of stock a lot) I use Shell Rotella 5-40 synthetic.
9Back to top Go down   oil & coolant Empty filter? Sat May 03, 2014 3:23 pm
emmanuelfiadjoe
emmanuelfiadjoe
thanks to you all.
i read somewhere on the forum that the filter element is the same as that of a bmw car. is this right?
Region: Europe
VIN: 0018945
10Back to top Go down   oil & coolant Empty Re: oil & coolant Sat May 03, 2014 3:51 pm
Avenger GT
Avenger GT
emmanuelfiadjoe wrote:thanks to you all.
Be very careful of car filters. Most of them are painted on the outside, and not designed for use inside the engine as the K bikes. Paint may come off them when immersed in hot oil, causing blockage of oil ways with disastrous results. Proper K bike filters are not painted.
11Back to top Go down   oil & coolant Empty thanks for the caution Sat May 03, 2014 4:08 pm
emmanuelfiadjoe
emmanuelfiadjoe
so what do i do now? there is no bmw motorbike dealer or shop in my country. how do i proceed?
Region: Europe
VIN: 0018945
12Back to top Go down   oil & coolant Empty Re: oil & coolant Sat May 03, 2014 4:17 pm
k-rider
k-rider
emmanuelfiadjoe wrote:so what do i do now? there is no bmw motorbike dealer or shop in my country. how do i proceed?
Try motobins.uk or
motorworks. Uk
k-rider
13Back to top Go down   oil & coolant Empty Re: oil & coolant Sat May 03, 2014 4:21 pm
k-rider
k-rider
14Back to top Go down   oil & coolant Empty Re: oil & coolant Sat May 03, 2014 4:29 pm
Oil filter - Bosch 72161.  They often have a sticker on them.  Remove it before installing.
15Back to top Go down   oil & coolant Empty Re: oil & coolant Sat May 03, 2014 6:18 pm
I don't know how often the dealer lists at BMW is updated, so I don't know if this one in
your neighbour country still exists.
The search facility says that it should be several dealers in Togo.
You could try to find one in the countries nearby, go to BMW motorrad international,
locate a dealer.
oil & coolant Togo10
16Back to top Go down   oil & coolant Empty Re: oil & coolant Sat May 03, 2014 9:35 pm
Snod Blatter
Snod Blatter
Avenger GT wrote:Be very careful of car filters. Most of them are painted on the outside, and not designed for use inside the engine as the K bikes. Paint may come off them when immersed in hot oil, causing blockage of oil ways with disastrous results. Proper K bike filters are not painted.
Is this a real concern? I have just fitted such a filter (Filtrex branded) ~20 miles ago, eeep! I didn't know that it sat in oil until half a litre fell out the engine onto the floor either when I tried to be clever and see if it leaked past the seal, what a stupid design! Why bother with a canister type filter at all??
17Back to top Go down   oil & coolant Empty Re: oil & coolant Sat May 03, 2014 9:43 pm
emmanuelfiadjoe wrote:i'v found fully synthetic shell helix ultra 5w-40 for high performance engines. will that be ok for my engine?
That is what I would be using.
List of suitable filters
  • Purolator PL10241 / PL25230
  • Mobil1 M1-102
  • Bosch 3330
  • Supertech ST3614
  • AMSOil SMF 122
  • EMGO 10-26740
  • Fram PH6063
  • HiFlo  HF126
  • Ryco  Z418
  • Purolator ML16825
18Back to top Go down   oil & coolant Empty many thanks Mon May 05, 2014 11:47 am
emmanuelfiadjoe
emmanuelfiadjoe
thanks to you all, i'll go to the market and such
Region: Europe
VIN: 0018945
