1Back to top Go down   K100 gearbox input shaft spline Empty K100 gearbox input shaft spline on Sat May 03, 2014 12:01 pm
Oldracer
Oldracer
Does anyone know if the gearbox input shaft spline (the bit where the foot lever pushes on) is the same as any other BMW models, or indeed any other motorcycle models?
I know the K75/100/K1/K1100 are the same but are there any more with the same spline size?
I ask because i use k1100 levers and cut them down for the rearsets that i make for the K, but i think i am depleting the used stock available and would like to find an alternative.
Thanks,
Ben
http://www.bskspeedworks.co.uk
2Back to top Go down   K100 gearbox input shaft spline Empty Re: K100 gearbox input shaft spline on Sat May 03, 2014 8:37 pm
Quite a lot of the Hondas are the same. I wouldn't say all but many of the earlier Hondas such as the SL/XL Range of singles.
