1Back to top Go down   Oil Change Empty Oil Change on Mon May 05, 2014 12:02 pm
emmanuelfiadjoe
emmanuelfiadjoe
pls, I don't have the wrench to remove the oil filter. I've removed all the bolts holding the oil pan but its not dropping, any suggestions?
Also, the sealant available here is Abro RTV Silicone gasket maker & Abro 999 gasket maker. Are these ok?
Last edited by emmanuelfiadjoe on Mon May 05, 2014 12:19 pm; edited 2 times in total
Model: K 100 RS 83 (0502,0503,0513)
Series: K589 (k100, RS, RT, LT)
Production Month/Year: 07/1984
Region: Europe
VIN: 0018945
2Back to top Go down   Oil Change Empty Re: Oil Change on Mon May 05, 2014 12:06 pm
You don't need to remove the oil pan, only the round filter cover:
Oil Change Oil.filter.cover_small
The oil pan has sealant on it where it meets the sump.
Be careful not to strip the threads.
3Back to top Go down   Oil Change Empty no filter wrench on Mon May 05, 2014 12:15 pm
emmanuelfiadjoe
emmanuelfiadjoe
I don't have a wrench to remove the filter, that's why I want to remove the oil pan so i can remove it by hand.
pls check the first post, I've edited it
Region: Europe
VIN: 0018945
4Back to top Go down   Oil Change Empty Re: Oil Change on Mon May 05, 2014 12:54 pm
Looks like either of those would work.
5Back to top Go down   Oil Change Empty Re: Oil Change on Mon May 05, 2014 1:32 pm
Kyle10
Kyle10
Pick up one of these (cheap), 76mm I believe:
Oil Change D164
1985 K100rt 0052183
1983 Honda VF750 007713
6Back to top Go down   Oil Change Empty the oil pan on Mon May 05, 2014 1:43 pm
emmanuelfiadjoe
emmanuelfiadjoe
& the oil pan, how do i drop it pls?
Region: Europe
VIN: 0018945
7Back to top Go down   Oil Change Empty Re: Oil Change on Mon May 05, 2014 1:50 pm
Kyle10
Kyle10
@emmanuelfiadjoe wrote:& the oil pan, how do i drop it pls?
K1100, K100; same thing basically re oil pan
1985 K100rt 0052183
8Back to top Go down   Oil Change Empty Re: Oil Change on Mon May 05, 2014 2:41 pm
Oil filter wrench: 76mm - 14 flutes
9Back to top Go down   Oil Change Empty Re: Oil Change on Mon May 05, 2014 2:57 pm
Rabidchiwawa007
Rabidchiwawa007
My oil filter wrench (if it's not turnable by hand) is two screw drivers stabbed in to the oil filter on either side, then turn it loose.  Razz   Then oil the rubber of the new one and turn it till it barely resists.  They don't need to be tight at all.  Even if it wants to unthread from vibrations, the sump plate keeps it from doing so.
1968 BSA Lightning
10Back to top Go down   Oil Change Empty Re: Oil Change on Mon May 05, 2014 3:29 pm
zonenfeile
zonenfeile
@emmanuelfiadjoe wrote:I don't have a wrench to remove the filter, that's why I want to remove the oil pan so i can remove it by hand.
its not us with the "read first" - its you
get the wrench
same as bashing the wrong key into the ingnition until it moves
and pls read the fu manual first
ex K1100/2
K- Wiki - or rtfm first
Regards from Hamburg
Olaf
11Back to top Go down   Oil Change Empty Re: Oil Change on Mon May 05, 2014 3:33 pm
Kyle10
Kyle10
@zonenfeile wrote:its not us with the "read first" - its you
get the wrench
Well, someone had to come out and say it...
 lol!
1985 K100rt 0052183
12Back to top Go down   Oil Change Empty well appreciated on Mon May 05, 2014 4:49 pm
emmanuelfiadjoe
emmanuelfiadjoe
i appreciate your comments. I'm done reading the riders handbook & part of the hanes/clymer's. the thing is that your help is quite specific & has always resolved the bikes problems. anyway, i got the oil filter out with a chain. will check the market for a new one, & of course, the wrench.
thanks
Region: Europe
VIN: 0018945
13Back to top Go down   Oil Change Empty Re: Oil Change on Mon May 05, 2014 7:11 pm
14Back to top Go down   Oil Change Empty thanks on Tue May 06, 2014 5:02 am
emmanuelfiadjoe
emmanuelfiadjoe
many thanks
 Inge K
Region: Europe
VIN: 0018945
15Back to top Go down   Oil Change Empty still no alternative on the market on Tue May 06, 2014 4:44 pm
emmanuelfiadjoe
emmanuelfiadjoe
i combed the market today but did not get any of the recommended alternative oil filters. in the interim, i plan to flush the old one with petrol & reuse.
Region: Europe
VIN: 0018945
16Back to top Go down   Oil Change Empty Re: Oil Change on Tue May 06, 2014 4:58 pm
k75RT Keith
k75RT Keith
WIX  51348
Bosch  3330
Link below has more options.
http://www.ibmwr.org/otech/partsubs.shtml#kbikes
17Back to top Go down   Oil Change Empty thanks on Tue May 06, 2014 7:06 pm
emmanuelfiadjoe
emmanuelfiadjoe
already checked the Bosch but wasn't available
Region: Europe
VIN: 0018945
18Back to top Go down   Oil Change Empty Re: Oil Change on Tue May 06, 2014 7:19 pm
10-ring
10-ring
I just installed a K&N KN163 oil filter and casteroil GTX 20w-50 oil 20 min ago.
19Back to top Go down   Oil Change Empty Re: Oil Change on Tue May 06, 2014 9:15 pm
One of the members in Europe may be able to post some to you along with a removal tool.
I will do it from Australia if you want to. You can pay with PayPal.
20Back to top Go down   Oil Change Empty Re: Oil Change on Tue May 06, 2014 10:06 pm
Kyle10
Kyle10
@emmanuelfiadjoe wrote:i combed the market today but did not get any of the recommended alternative oil filters. in the interim, i plan to flush the old one with petrol & reuse.
Don't do it! If at all possible wait until you can secure a new filter.
No matter what you do in an attempt to clean the old filter it will remain polluted.
Patience over possibly subjecting the engine to undue wear and harm.
1985 K100rt 0052183
21Back to top Go down   Oil Change Empty Re: Oil Change on Tue May 06, 2014 10:16 pm
I would run the old one with new oil until you can get your hands on the "right" one.  The new oil will help and using an old filter for a couple of thousand extra miles will not make your bike explode.
22Back to top Go down   Oil Change Empty Re: Oil Change on Wed May 07, 2014 6:02 am
rawdonball
rawdonball
Mate. Confirm you checked for a Z418. It is also used on the Totota V6 Camry + on some Hilux Utes and on some Landrovers. All common vehicles in my part of Africa (ex) - to the South of you.
23Back to top Go down   Oil Change Empty Checking ... on Wed May 07, 2014 9:37 am
emmanuelfiadjoe
emmanuelfiadjoe
I just called Toyota Ghana Limited to check on the Ryco Z418, they'll get in touch in an hour. I hope they have it because I teach in @ least three different places in the Accra metropolis, I can't meet these appointments without the motor bike: there is always heavy traffic. If they don't have any, I'll have to use the old one & then pay someone to buy one for me on the forum.
Region: Europe
VIN: 0018945
24Back to top Go down   Oil Change Empty Re: Oil Change on Wed May 07, 2014 10:04 am
BMW 3 series car filters fit, but they don't come with the o ring for the circular cover and don't come with the sump nut crush washer. If you are careful you can reuse the o ring and the crush washer.
1997 K1100LT 0188024 Wotan Mystic Red 58,645 now 100,380 miles
1983 K100RS 0011171 Fricka 29,495 miles Damn K Pox Its a Bat outta Hell No 33,600 miles
25Back to top Go down   Oil Change Empty crush washer? on Wed May 07, 2014 10:43 am
emmanuelfiadjoe
emmanuelfiadjoe
i didn't notice any crush washer when i removed the oil filter. help me out here pls
Region: Europe
VIN: 0018945
26Back to top Go down   Oil Change Empty Re: Oil Change on Wed May 07, 2014 11:51 am
@emmanuelfiadjoe wrote:i didn't notice any crush washer when i removed the oil filter. help me out here pls
He said "sump nut crush washer". He meant the oil drain bolt in the sump.
27Back to top Go down   Oil Change Empty pressure release valve on Wed May 07, 2014 12:22 pm
emmanuelfiadjoe
emmanuelfiadjoe
is the black thing i see inside the original oil filter the pressure release valve?
Region: Europe
VIN: 0018945
28Back to top Go down   Oil Change Empty Re: Oil Change on Wed May 07, 2014 1:23 pm
japuentes
japuentes
Hi there, as per their website, GUD filters (http://www.gud.co.za) makes and oil filter equivalent to wix 51348, their number part is Z217 and is supposed to be available in Ghana´s  market.
Hope this helps.
Best regards
JAP
Oil Change 2854237993 1988 K100RS SE/ABS
29Back to top Go down   Oil Change Empty Gud? on Wed May 07, 2014 3:32 pm
emmanuelfiadjoe
emmanuelfiadjoe
thanks man, will check the market tomorrow, but has it the pressure release valve? I understand my oil pump may be damaged if the oil filter doesn't have the valve with the right pressure designation.
Region: Europe
VIN: 0018945
30Back to top Go down   Oil Change Empty Re: Oil Change on Wed May 07, 2014 4:23 pm
japuentes
japuentes
Yes it has the pressure relief valve, only is set to open earlier (at  low pressure) than the original, this means that you'll have to make oil changes at 5000Km instead of 7000 or 10000.
Best regards
JAP
31Back to top Go down   Oil Change Empty Re: Oil Change on Thu May 08, 2014 11:14 am
@japuentes wrote:Yes it has the pressure relief valve, only is set to open earlier (at  low pressure) than the original, this means that you'll have to make oil changes at 5000Km instead of 7000 or 10000.
Best regards
JAP
I don't understand how you know what the PRV on either filter is set at. I also don't understand how this relates to the oil change interval.
32Back to top Go down   Oil Change Empty Re: Oil Change on Thu May 08, 2014 11:32 am
japuentes
japuentes
Hi, the PRV set point is in the filter´s data sheet. The PRV opens wen the pressure drop through the filter reaches the set point, pressure drop is an indicative of the filter´s cleanliness and hence of the flow that is passing trough it, the higher the drop the lesser the flow, for each model this means that soon or late the valve will open and the oil will pass unfiltered, a filter with a greater set up will take more time to reach it so you can change it less frequently, ie: every two oil changes and no at every one, or you can go with a synthetic oil and make the change at 10000km instead of the 5000 allowed by the mineral ones.
I use mineral oil and WIX5138 filters every 5000 km.
Best regards
JAP
33Back to top Go down   Oil Change Empty synthetic? on Thu May 08, 2014 11:59 am
emmanuelfiadjoe
emmanuelfiadjoe
I checked online and the GUD has PRV rated @ 0.69 bar (10 PSI), the bmw genuine oil filter' s is @ 9-11 PSI. that's not much of a difference. I'm yet to close from school to check if I'll get the GUD. Anyway, I plan to use shell ultra 5w-40 full synthetic.
Region: Europe
VIN: 0018945
34Back to top Go down   Oil Change Empty still futile on Thu May 08, 2014 6:30 pm
emmanuelfiadjoe
emmanuelfiadjoe
Japs, I located a dealer of Guds & Purolators but he didn,t have the stipulated ones for the K. anyway, I bought a fully synthetic oil (PETROMIN SUPER SYNTHETIC GF4 5W-40), I also found the wrench for removing the oil filter. I flushed it with petrol & reused it with the new oil.
Region: Europe
VIN: 0018945
35Back to top Go down   Oil Change Empty Re: Oil Change on Thu May 08, 2014 6:41 pm
japuentes
japuentes
Good to hear you are on the road, hope you'll find the filter.
Best regards
JAP
36Back to top Go down   Oil Change Empty thanks on Thu May 08, 2014 7:54 pm
emmanuelfiadjoe
emmanuelfiadjoe
thanks jap
Region: Europe
VIN: 0018945
