1Back to top Go down   Temp sender Empty Temp sender Wed May 07, 2014 7:30 pm
billtr96sn
billtr96sn
I am in the middle of fitting a fuel gauge (all working now) and a water temp gauge and I would like to know if this will do the job as the sender, thanks. I did try using the search function but found nothing to help me.
http://www.ebay.co.uk/itm/400572843963?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Something witty is supposed to go here... help!! Temp sender Uk-log10
http://www.billsbikechat.co.uk
2Back to top Go down   Temp sender Empty Re: Temp sender Sun May 11, 2014 8:37 am
billtr96sn
billtr96sn
No one??
3Back to top Go down   Temp sender Empty Re: Temp sender Sun May 11, 2014 8:47 am
ReneZ
ReneZ
I don't know if it is the right one (they normally have a blue collar) and I don't see the threat, but why don't you call one of the usual suspects? Motorworks/Motobins/James Sherlock?
Rene
BMW K100 - 1985 (0030029) Scotland Temp sender Rain
4Back to top Go down   Temp sender Empty Re: Temp sender Sun May 11, 2014 8:56 am
billtr96sn
billtr96sn
Because theirs are £26 and this one is £5
5Back to top Go down   Temp sender Empty Re: Temp sender Sun May 11, 2014 8:58 am
billtr96sn
billtr96sn
The thread size to the one I have linked is 10mm x 1
6Back to top Go down   Temp sender Empty Re: Temp sender Sun May 11, 2014 11:08 am
If you obsolutely want one, buy one.....
It might not show the correct value on the instrument, but I guess it wont be that far of......
You soon see what is the normal value with this set up....and what is outside of this normal value.
Take care when thightening this non OEM sensor, the easily snap of.....
It have been covered here on this forum earlier, a non OEM sensor from one of the three earlier mentioned suppliers.
If you find it total useless, you have lost £5 and 0,5 hour of your life....and must buy a OEM sensor.
7Back to top Go down   Temp sender Empty Re: Temp sender Sun May 11, 2014 11:13 am
ReneZ
ReneZ
Having looked into this a few years before when I installed a temp gauge on my bike I understand there are two different type of sensors that go with different type of gauges. One for water, the other for oil. Both are about 50 Ohms for mid level gauge, but the water one is mid-gauge at 100C (correct?) and the oil one at 80C IIRC. Most temp gauges are the same in setup (expecting 50 Ohms for mid-level), so the right sensor should work with various brands of gauges.
Rene
8Back to top Go down   Temp sender Empty Re: Temp sender Sun May 11, 2014 3:21 pm
billtr96sn
billtr96sn
Thanks all (especially you Inge,as you have my style of thinking). If it works I shall reportback and let you know, if not, I shall keep quite and hope you all forget this sorry episode of
my life.  Smile
9Back to top Go down   Temp sender Empty Re: Temp sender Thu May 22, 2014 1:58 pm
billtr96sn
billtr96sn
It works absolutely fine!
10Back to top Go down   Temp sender Empty Re: Temp sender Thu May 22, 2014 2:48 pm
mr grumpy
mr grumpy
Thank you for that link. My temperature gauge has never worked but I didn't care £26 worth to fix it, for a fiver I shall give it a try.
K100RS 16v
