1Back to top Go down   K100LT final drive  Empty K100LT final drive on Fri May 09, 2014 3:12 am
floyd
floyd
I have 3 that have seen better days. damn heavy and expensive paper weights really.
The 3rd which is ok has one of the rotor bolts sheared off in place and I cant extract it. My easy out snapped off in there Sad
Has anyone got a decent early k100 rear drive they wanna sell before I buy one from the states?
2Back to top Go down   K100LT final drive  Empty K100LT final drive on Sat May 10, 2014 4:56 am
Hey Floyd I,ve been driving around for a year with a sheared off disc holding bolt in there, just ground it flush with
the surface (Dremel), doesn't seem to be doing any damage. I broke off my ezyout in there as well, they are a tough thing to get out, and entirely unneeded except to line up the holes when putting the wheel back on.
3Back to top Go down   K100LT final drive  Empty Re: K100LT final drive on Sat May 10, 2014 6:33 am
If you want to replace the drive due to the bolt then you are wasting your cash.
Not needed. As Mr RT said.
4Back to top Go down   K100LT final drive  Empty Re: K100LT final drive on Sat May 10, 2014 6:46 am
On the rear its the same as a car. The wheel bolts hold the rotor in place. The bolts in the rotor are only to locate it and stop it falling off. I just replaced the rear rotor and the bolts didn't come out easily. I now have one bolt but 4 good wheelbolts.
1997 K1100LT 0188024 Wotan Mystic Red 689 58,645 now 100,380 miles
1983 K100RS 0011171 Fricka 606 29,495 miles Damn K Pox Its a Bat outta Hell No 33,600 miles
5Back to top Go down   K100LT final drive  Empty Re: K100LT final drive on Sat May 10, 2014 7:37 am
floyd
floyd
Thank you all greatly gents. I'm now all the more wiser and a few hundred dollars better offi was wondering why they chose such small bolts to hold the rotor on... Embarassed
6Back to top Go down   K100LT final drive  Empty Re: K100LT final drive on Sat May 10, 2014 9:24 am
@floyd wrote:was wondering why they chose such small bolts to hold the rotor on... Embarassed
On the cars it's even worse, only one small screw......... affraid   Rolling Eyes .
