1Back to top Go down   FS-1985 Luftmeister exhaust system Empty FS-1985 Luftmeister exhaust system on Sat May 31, 2014 2:37 pm
enzo
enzo
I went to a stock system from a 91 LT. Here is the old system which as best as I can tell is a Luftmeister. http://www.ebay.com/itm/121353219932?item=121353219932&viewitem=&vxp=mtr
1985 BMW K100RS Alaska Blue
2012 KTM 500 XC-W
2Back to top Go down   FS-1985 Luftmeister exhaust system Empty Re: FS-1985 Luftmeister exhaust system on Sun Jun 01, 2014 1:34 am
kioolt
kioolt
In your ebay ad you state that you know it will fit the 16v engine because it came off a 91 K100LT.  The 91 K100LT is an 8 valve engine.
2004 R1150RT 186,800 miles
1991 K100LT 128,700 miles
1982 R100RT 106,900 miles
Total 422,400 BMW miles
AMA,BMWRA,BMWMOA
3Back to top Go down   FS-1985 Luftmeister exhaust system Empty Re: FS-1985 Luftmeister exhaust system on Sun Jun 01, 2014 2:07 am
It will fit either 8v or 16v.  The spacing between the ports is the same, stud placement is the same too.  The 16v ports are a bit further forward though, as the entire system will be mounted a bit further forward, the muffler mount will not line up and would need to be modified.
I've put 8v systems on 16v bikes before, they do fit.
'87 K100RS/HRD sidecar (1100 motor)  sc25
'92 K100RS-16v (Paint it Black)
FS-1985 Luftmeister exhaust system K-dogs10
