1Back to top Go down   Pin Out for Dash Harness? Empty Pin Out for Dash Harness? on Wed Jun 11, 2014 12:51 pm
Finnigan
Finnigan
Does anyone have or know where to get a diagram of the connector that attaches to the back of the stock dashboard?  i.e. what each wire is for
1990 k100LT
2Back to top Go down   Pin Out for Dash Harness? Empty Re: Pin Out for Dash Harness? on Wed Jun 11, 2014 1:21 pm
From Flyingbrick..........if you got ABS, the warning lamps is connected to pin 8 & 14.
Pin Out for Dash Harness? Kontak10
3Back to top Go down   Pin Out for Dash Harness? Empty Re: Pin Out for Dash Harness? on Wed Jun 11, 2014 1:23 pm
Finnigan
Finnigan
Thanks, er I guess I could use google translate but is there an English version?
1990 k100LT
4Back to top Go down   Pin Out for Dash Harness? Empty Re: Pin Out for Dash Harness? on Wed Jun 11, 2014 3:02 pm
Finnigan
Finnigan
I've translated to this, need help identifying some of the lesser known terms like "mass"
Pin Out for Dash Harness? Draft10
1990 k100LT
5Back to top Go down   Pin Out for Dash Harness? Empty Re: Pin Out for Dash Harness? on Wed Jun 11, 2014 4:25 pm
Finnigan
Finnigan
Just a few questions i have is:
1) Which pin is the speed sensor?
2) Which Tachometer pin should I use for a digital tachometer?
1990 k100LT
6Back to top Go down   Pin Out for Dash Harness? Empty Re: Pin Out for Dash Harness? on Wed Jun 11, 2014 5:24 pm
This one is in the download section Smile
Pin Out for Dash Harness? Instrument%20cluster%20plug
Pin Out for Dash Harness? Frog15Pin Out for Dash Harness? Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
7Back to top Go down   Pin Out for Dash Harness? Empty Re: Pin Out for Dash Harness? on Wed Jun 11, 2014 6:41 pm
Finnigan
Finnigan
Thanks thats useful, my question still remains about the speedometer sensor and which wire to use for a digi tach
1990 k100LT
8Back to top Go down   Pin Out for Dash Harness? Empty Re: Pin Out for Dash Harness? on Wed Jun 11, 2014 8:38 pm
Speedo sensor is 23 (brown) and 22 (yellow).  It is a sine wave, 0.7V peak-peak.  There are 6 pulses per rear wheel revolution.
Tach is 16 (black/blue). It is a negative going 12 volt signal.
9Back to top Go down   Pin Out for Dash Harness? Empty Re: Pin Out for Dash Harness? on Wed Jun 11, 2014 8:45 pm
Finnigan
Finnigan
Thats exactly what I needed to know, thats a ton!
1990 k100LT
10Back to top Go down   Pin Out for Dash Harness? Empty Re: Pin Out for Dash Harness? on Fri Jul 11, 2014 8:10 pm
Finnigan
Finnigan
Does anyone know what to use for the neutral dummy light?
1990 k100LT
