ffbikersa
ffbikersa
Some vandals have broken the On/Off switch lever on my K 100 LT - so if someone have broken right-hand switch gear and is willing to part with just this small piece, pls. contact me.
Needed: K 100/K 75 On/Off switch lever - or complete right-hand switch gear On-off10
a bit like chooks teeth , a very hard to find item , as a part.
I was considering once , how would it be to use some plastic putty and use the original as a mould to make a new one ?
1987 K100RT  Ex- police
1989 K100LT  Ol' Blue and "Kart" the Kamper trailer.  now KAPUT .
Needed: K 100/K 75 On/Off switch lever - or complete right-hand switch gear 10_x_110
3Back to top Go down   Needed: K 100/K 75 On/Off switch lever - or complete right-hand switch gear Empty I was thinking of that too on Tue Jul 08, 2014 5:36 am
ffbikersa
ffbikersa
groverK wrote:a bit like chooks teeth , a very hard to find item , as a part.
I had the same idea - that's why I was searching the pavement this morning to find the missing piece. Repair with 60-second glue might have worked too. Unfortunately, the moron who broke it probably threw this very small red plastic piece in very high grass nearby. Looking for needle in a haystack, literally  Rolling Eyes
Mate,
I read on here somewhere that your broken switch should not be played with.
Apart from cosmetic value it is better to leave it alone.
Turn the bike on and off with the key. Leave the kill switch in the on position.
That is what I do because I am a lemming.
Convenience wants me to use the switch because when you stop you are usually in gear and the easy option is a flick of the thumb and the bike turns off.
Put it in neutral, hand off the clutch, turn the key off. At the same time take the key out and put it in your pocket. The number of times I have looked for my key to find it still in the ignition after working all day.
5Back to top Go down   Needed: K 100/K 75 On/Off switch lever - or complete right-hand switch gear Empty Yep, it's a matter of convenience on Tue Jul 08, 2014 6:36 am
ffbikersa
ffbikersa
@rosskko wrote:Mate,
Same happens to me - though, I more tend to forget my key in the topcase lock.
I can still turn the switch in on or off position with my fingers - though, not sure if it will work with thicker winter gloves as well
