Just a quick one if someone is near the pc to help.
Broken down.
Irratic running then died at lights.
Starter motor connection was bad.
Tightened it up. Would not start on button but clutched it ok.
Would not start this arvo.
Bump start again.
Died after 2km
Stuck at a servo.
Fuel pump works, pulled it fromt he tank to check.
Fuel pump not working in the tank.
Hit the starter, bit of a whirr, pump stops and tacho needle goes past redline.
Battery ok.
When I had it running, bump start after pulling fuel pump it makes an intermittent clunk. Just once, waits a bit then clunks again.
Thinking starter is kaput or in need of a service?
A hasty reply is a good reply.
rosskkko
Last edited by rosskko on Mon Dec 22, 2014 6:56 am; edited 1 time in total (Reason for editing : solved)
sounds more like a fuse to me rossko
good luck
Which bike? It goes clunk, engine? starter? or fuel pump?
Thanks guys.
Thinking alternator
Bump started after replacing alt and now is running
Died last time when I turned on the headlight
All lights on now and running fine.
phew....
good solve rossko
Cheers guys, back home and good.
Seems the alternator was not charging and the battery was fine on the test, about 12 and a bit, but I failed to check it when the engine was running rough.
Charge light also failed to come on? Blown globe? One more thing to check.
Old alternator runs smooth so I have no idea what the random knock was. Monkey knuts were good.
Time for a strip down and a bit of a check.
Jez
Jez
Sounds similar to the way mine was behaving before I did the starter motor brushes. Crazy but true.
The clunk? hmmm, dunno about that.
84 K100 RS
Chassis number     0080546
rosskko wrote:Cheers guys, back home and good.
brushes to the alternator ? no field current ? = no charge indicator
Cheers Charlie
Just had a chat to Rick about the same thing.
Gunna have a gander and replace as necessary.
cheap as chips if you ask an auto electrician for a regulator to suit a vw .....don't mention a motor bike at all
Hey rooossskkkkoooo, this may help.
It's from a Range Rover, but it's quite similar to our K bikes. Sort of. In a way. Kinder. Maybe.
Anyhoo, have a look.
