1Back to top Go down   air bypass screw o ring Empty air bypass screw o ring Sun Aug 10, 2014 4:59 am
Packo
Packo
Does anyone know where to buy the o rings for the air bypass screws in Aust.
The smallest ones available from Repco or Supercheap are ok for ID but they are too thick
If I need to go to a more specialised outlet is there a particular size I should ask for
Mike
2Back to top Go down   air bypass screw o ring Empty Re: air bypass screw o ring Sun Aug 10, 2014 5:26 am
I don't know what the exact size is but I got them at a bearing supply joint.  Robco and superexpensive have rarely got anything that goes close
3Back to top Go down   air bypass screw o ring Empty Re: air bypass screw o ring Sun Aug 10, 2014 6:00 am
Packo
Packo
thanks Rick I will give that a go
