1Back to top Go down   Wanted: Fuel Pump Vibration Damper Empty Wanted: Fuel Pump Vibration Damper on Mon Aug 18, 2014 2:05 pm
Shep
Shep
I would like to purchase a vibration damper for a July 1984 USA production K100 RS. The OEM site says the following part number 16 12 1 450 712 is good up to the production date of May 1985.
If the coffee basket style filter is available I would purchase that as well.
The one I have as can be seen is dilapidated.
Is there another solution as I am trying to not spend $70 to 90 US  for this particular item in the rehabilitation of a $600 bike?
Shep
2Back to top Go down   Wanted: Fuel Pump Vibration Damper Empty Re: Wanted: Fuel Pump Vibration Damper on Mon Aug 18, 2014 2:09 pm
Shep
Shep
What is that all about -- my picture did not post!!!!
S
3Back to top Go down   Wanted: Fuel Pump Vibration Damper Empty Re: Wanted: Fuel Pump Vibration Damper on Mon Aug 18, 2014 2:15 pm
Shep
Shep
Wanted: Fuel Pump Vibration Damper Z
4Back to top Go down   Wanted: Fuel Pump Vibration Damper Empty Re: Wanted: Fuel Pump Vibration Damper on Mon Aug 18, 2014 5:57 pm
Comberjohn
Comberjohn
I had the same problem.
For a new part, the cost from Motorworks was similar. I was fortunate to be able to pick up a 2nd hand one. They do turn up.
Not sure what else you can use.
Life is not a rehearsal.
2010 VFR 1200F DCT
2010 R1200GS(gone)
1986 K100 Silver(gone)
2012 K1600GT(gone)
1984 K100 Red(gone)
5Back to top Go down   Wanted: Fuel Pump Vibration Damper Empty Re: Wanted: Fuel Pump Vibration Damper on Mon Aug 18, 2014 6:58 pm
Plenty of life left in that one.
Here is one I prepared earlier.
Wanted: Fuel Pump Vibration Damper K100211
6Back to top Go down   Wanted: Fuel Pump Vibration Damper Empty Re: Wanted: Fuel Pump Vibration Damper on Tue Aug 19, 2014 12:48 am
Shep
Shep
Good God -- The word neglect doesn't even begin to describe the pieces in that picture!!!
S
7Back to top Go down   Wanted: Fuel Pump Vibration Damper Empty Re: Wanted: Fuel Pump Vibration Damper on Tue Aug 19, 2014 2:00 am
Last edited by RicK G on Tue Aug 19, 2014 3:52 am; edited 1 time in total (Reason for editing : Preparing for lunch)
8Back to top Go down   Wanted: Fuel Pump Vibration Damper Empty Re: Wanted: Fuel Pump Vibration Damper on Tue Aug 19, 2014 2:15 am
Unfortunately, that part number does the later models...EME don't supply an OEM-like replacement for the early jobs.
1977 R75/7-R100 grey, '87 K100RS red, '93 K11-K12 aka 'Big Block' black, '96 K1100RS black, '98 K1200RS red, '09 K1300GT red, & 2013 R1200RT-Polizia black & white.
9Back to top Go down   Wanted: Fuel Pump Vibration Damper Empty Re: Wanted: Fuel Pump Vibration Damper on Tue Aug 19, 2014 3:37 am
@Shep wrote:Good God -- The word neglect doesn't even begin to describe the pieces in that picture!!!
S
Not sure what you mean?
The screwdriver still works and with a bit of WD40 the pliers will be good as new. What a Face
10Back to top Go down   Wanted: Fuel Pump Vibration Damper Empty Re: Wanted: Fuel Pump Vibration Damper on Tue Aug 19, 2014 3:55 am
That's absolutely disgusting RossKo putting up filthy pictures like that, next it will be naked Ks
11Back to top Go down   Wanted: Fuel Pump Vibration Damper Empty Did you try beemer boneyard? on Fri Sep 19, 2014 8:28 pm
John in Phoenix
John in Phoenix
...I think that is where I found the one I needed for a K1100RS.
Thank you!
John in Phoenix
