1Back to top Go down    Fitting different coils on Tue Aug 19, 2014 6:02 am
floyd
floyd
Can the electrickery gurus please advise:
Would one be able to modify the stock K100 wiring loom to acceptTHESE COILSfrom BSK Speedworks with no probs?
They use them on their K100 race bike with an alternative electronic fuel injection system and these coils plug directly into their bespoke wiring loom.
Only reason I ask is it seems a good price for brand new coils and RAM leads. For about the same price as 2nd hand orange stack coils and the RAM leads you can get this.
They only have 3 wires going in, instead of the 5 or so in the stock coils....
2Back to top Go down    Re: Fitting different coils on Tue Aug 19, 2014 6:22 am
They are the K1200 coils and have the same output voltage and impedance as the K1100 coils but come as a single item.
The primary resistance is 1.2 ohms as against the near 3 ohms of the K100 coils.
You could probably use a 2.2ohm resistor in each primary feed but that will lower the output voltage by about half or a bit more which would be heaps enough to electrocute a rat but may cause problems with a K100.
Give me a while and I will check out some other things.
That didn't take long
http://accel-motorcycle.com/motorcylce-and-atv/ignition-coils/universal-super-coils-black.html
"Every normal man must be tempted, at times, to spit upon his hands, hoist the black flag, and begin slitting throats." from Mencken's 1919 Prejudices
3Back to top Go down    Re: Fitting different coils on Tue Aug 19, 2014 7:11 am
@RicK G wrote:They are the K1200 coils and have the same output voltage and impedance as the K1100 coils but come as a single item.
The coils for the K1200 look a bit different..............
The coils from BSK is for a Ford Mondeo III 1.8, I would guess that the spec is different.
4Back to top Go down    Re: Fitting different coils on Tue Aug 19, 2014 7:19 am
Ah Ha Ingapedia strikes again. I remember that he runs an after market FI system and I would assume that the ignition is integral with it, so who but Ben knows and that may be a trade secret.
5Back to top Go down    Re: Fitting different coils on Tue Aug 19, 2014 9:05 am
NOOO...! do not use a resistor to load up the impedances of the primary coils ....it will just act as a huge current limit with unwanted side affects
would be better to use a higher resistance - impedance coil than to use a lower one and load it up with any resistor
just what make sense to me
6Back to top Go down    Re: Fitting different coils on Tue Feb 13, 2018 12:00 pm
woodgeek
woodgeek
@RicK G wrote:Give me a while and I will check out some other things.
Has anyone documented fitting Accel universal coils to their K? My 1985 K100 has the original, solid black coils and one of them measures bad.
