1Back to top Go down   What Grease? Empty What Grease? on Tue Aug 26, 2014 12:41 pm
Puccini
Is the grease that's used on the big computer just common dialectric grease or something else?
2Back to top Go down   What Grease? Empty Re: What Grease? on Tue Aug 26, 2014 1:49 pm
the.postman
Mine's as clean as a whistle. always has been. I could understand somebody putting a light smear of something to keep torrential rain out, but it's not the norm.
1984 srx 600
1986 cbr1000f/h
3Back to top Go down   What Grease? Empty Re: What Grease? on Tue Aug 26, 2014 8:30 pm
There was never any grease put there from the factory. I have come across connectors like that where dielectric grease has been used but if the seal on the plug is working properly it should not be needed.
I would suggest removing all the grease and dry it out then put a new seal in place. Often the plugs don't get seated correctly and water gets in so the owner or the mechanic thinks the seal is not adequate and throws some dielectric grease in where correctly seating the plug would have done the job.
4Back to top Go down   What Grease? Empty Grease? on Fri Sep 19, 2014 8:23 pm
John in Phoenix
John in Phoenix
A similar grease called "DC-4" is used in the aviation industry.  It displaces water, and causes no harm.  I use it on battery terminals, to ward off corrosion.
Thank you!
John in Phoenix
5Back to top Go down   What Grease? Empty Re: What Grease? on Sun Sep 21, 2014 7:09 am
SEGAFREDO
SEGAFREDO
I use this, it is a very good product for all electric connexions  Wink
What Grease? Images?q=tbn:ANd9GcQlnSpn-chSqUId3W5pLvG-lYfU1phh2q_zvybKrtXTnZMlxB1N
