1Back to top Go down   K1100rs plug leads Empty K1100rs plug leads Mon Feb 01, 2016 7:41 pm
Silly noob question but how do I tell if my plug leads are resistor type?
K1100rs plug leads Ir-log1188....May contain nuts!K1100rs plug leads Ir-log11
K75RTP - 1994
2Back to top Go down   K1100rs plug leads Empty Re: K1100rs plug leads Mon Feb 01, 2016 7:54 pm
measure them with a DMM
 K1100rs plug leads Austra12    Fuel:  95 Octane
3Back to top Go down   K1100rs plug leads Empty Re: K1100rs plug leads Mon Feb 01, 2016 9:45 pm
Cheers Mein Kapitan but I'm crap with those things. I was hoping there might be a simpler way !
K75RTP - 1994
4Back to top Go down   K1100rs plug leads Empty Re: K1100rs plug leads Mon Feb 01, 2016 10:05 pm
Are the plug leads non OEM Will?
5Back to top Go down   K1100rs plug leads Empty Re: K1100rs plug leads Tue Feb 02, 2016 7:23 am
It appears so Rick!
The bike is a 95 K1100rs (see new avatar) with 90k miles on it. I picked it up for a song over Christmas with forum help from Olaf. It has a few issues to sort out. The first being a dicky ignition (done) and the second rough running/missing at lower revs which seems like poor spark to me so I'm suspecting plugs and/or leads but I want to get the right combo as I've picked up resistor plugs locally. I haven't got the old set out, the weather here is too cold and damp for the shed at present but I'd like to have it all to hand once I start.
I've just looked at a couple of youtube tutorials on how to measure Ohms with the DMM as Kaptain H. suggested so I think I can do that ok.
K75RTP - 1994
6Back to top Go down   K1100rs plug leads Empty Re: K1100rs plug leads Tue Feb 02, 2016 7:34 am
The K1100 is not as prone to system leaks as a K100 but might pay to check the O-rings under the manifold rubbers as they do on occasion get old and hard (we wish) and leak.
7Back to top Go down   K1100rs plug leads Empty Re: K1100rs plug leads Tue Feb 02, 2016 8:17 am
88KE wrote:....
I'd agree with that... for starters,
but more likely to be a crook lead or SP rather than mismatched resistance.
You can use your DMM to test your SPs as well. A non-resistor plug should read very low resistance of about 3ohm and resistor plugs about 5k ohm. Anything outside that and they're failing or kaput.
8Back to top Go down   K1100rs plug leads Empty Re: K1100rs plug leads Tue Feb 02, 2016 8:19 am
Check with user Beachcomber here if you're looking for new plug leads
9Back to top Go down   K1100rs plug leads Empty Re: K1100rs plug leads Tue Feb 02, 2016 11:08 am
duck wrote:Check with user Beachcomber here if you're looking for new plug leads
Thanks Duck.
K75RTP - 1994
10Back to top Go down   K1100rs plug leads Empty Re: K1100rs plug leads Tue Feb 02, 2016 12:29 pm
Realm Engineering  Will
same folks that do the shocks
all part of beachcomers designs
heres the link to the leads
http://www.realmengineering.com/page12.html
11Back to top Go down   K1100rs plug leads Empty Re: K1100rs plug leads Tue Feb 02, 2016 1:41 pm
charlie99 wrote:Realm Engineering  Will
Thanks Charlie. I was looking at them online yesterday. I think I'll be keeping my hand in my pocket till I get tyres sorted first if I can get away with it. Budgetary constraints and all that!
K75RTP - 1994
12Back to top Go down   K1100rs plug leads Empty Re: K1100rs plug leads Tue Feb 02, 2016 1:43 pm
I have a set of these - they even come in Red.
K1100rs plug leads Ir-log10
   ;BMW; K100RS Style Black 1987 105K Km     ;BMW; K1 Black 1993 60K Km     ;BMW;  K1100RS Black 1996       ;BMW; K1 Blue 1990 25K Miles
13Back to top Go down   K1100rs plug leads Empty Re: K1100rs plug leads Tue Feb 02, 2016 1:55 pm
and yellow for those into Flashy underwear  Razz
K75RTP - 1994
14Back to top Go down   K1100rs plug leads Empty Re: K1100rs plug leads Tue Feb 02, 2016 6:14 pm
"I have a set of these - they even come in Red."
Ditto.
Perfect fit. No troubles.
15Back to top Go down   K1100rs plug leads Empty Re: K1100rs plug leads Wed Feb 03, 2016 5:47 pm
Motorbike Mike
Motorbike Mike
88KE wrote:It appears so Rick!
A short while ago I picked up a K100 16v with an intermittent running problem. The guy I bought it from had swapped allsorts of parts but the problem persisted. I looked over the bike but found nothing wrong, the bike ran OK for ages and then one day it's on two cylinders.
I spent all morning fiddling about and in frustration I decided to move the bike away from the garage because of exhaust fumes. When I grabbed the lift handle it slipped from my grip thumping back into the frame......the bike fired on four again!
That little occurrence led me to look at the wiring that ran inside the frame near the lift handle and it turned out to be the loom that had a break inside the insulation. I still use that loom on my K100 track bike and it's never given any trouble since.
It's worth a look and good luck,
Mike.
16Back to top Go down   K1100rs plug leads Empty Re: K1100rs plug leads Wed Feb 03, 2016 6:47 pm
... and if you just want plain old kinky black, EME sell a set of NKG HT leads for the K for around the same price.
