1Back to top Go down   Clock Gremlin Empty Clock Gremlin on Fri Sep 12, 2014 5:18 pm
keefk11001
keefk11001
The LT has a bit of an annoying problem with the clock.
I put it right, turn on the ignition and fire up the motor and the clock springs from the right time to some random time on the 24hr clock. This doesn't happen every time, but enough to be irritating.
I've a feeling that the remedy is to take off the instrument binnacle and clean up the contacts, but anyone with a fully clothed K will know what a PIA that job is Sad
Any other thoughts please?
1997 K1100LT SE WB1052605V0236507
2Back to top Go down   Clock Gremlin Empty Re: Clock Gremlin on Sat Sep 13, 2014 12:31 am
You have the answer and you start by removing the left side fairing panel. Twisted Evil
3Back to top Go down   Clock Gremlin Empty Re: Clock Gremlin on Sat Sep 13, 2014 10:03 am
I might be lucky but have removed the instruments ...just by undoing the pockets  then fiddling around and undoing the allen keys holding the bracket
mind you this is a k100 rt  rather than a k1100 ....
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%OClock Gremlin Au-log10
4Back to top Go down   Clock Gremlin Empty Re: Clock Gremlin on Sat Sep 13, 2014 10:29 am
mind you this is a k100 rt  rather than a k1100 .... yep that's right. The K1100 is fixed to the body work not swinging out in the open like a K100.
5Back to top Go down   Clock Gremlin Empty Re: Clock Gremlin on Sat Sep 13, 2014 10:39 am
The access improves if you remove the screen carrier complete with mechanism and motor.
Strange this with the clock tho..........normally if it losing power for a fraction of a second it would reset and start from 00:00.
6Back to top Go down   Clock Gremlin Empty Re: Clock Gremlin on Sat Sep 13, 2014 11:59 am
cheers rick
7Back to top Go down   Clock Gremlin Empty Re: Clock Gremlin on Mon Oct 06, 2014 11:47 am
Grizzly
Grizzly
@Inge K. wrote:The access improves if you remove the screen carrier complete with mechanism and motor.
That is exactly what mine is doing.
Any pointers as to where to check first? Or is it just a case of methodically checking every wire?
Motorbike - Silver 1986 BMW K100 0008599 - 'Kylie' - written off
New Motorbike - 1998 Honda ST1100 Pan European ex-police and still without a name yet!
8Back to top Go down   Clock Gremlin Empty Re: Clock Gremlin on Mon Oct 06, 2014 12:03 pm
I would have started with checking fuse #3 contacts, then the connector behind the
instruments (pin #1, red/white wire), at last the internal contacts inside the instrument.
Clock Gremlin Kontak12
Also have a look in post 6 & 13 about the connector pins in this thread.
Last edited by Inge K. on Mon Oct 06, 2014 1:01 pm; edited 1 time in total (Reason for editing : Adding picture and link.)
9Back to top Go down   Clock Gremlin Empty Re: Clock Gremlin on Mon Oct 06, 2014 12:13 pm
I had some luck with one a few weeks ago. I pulled it apart and separated the LCD from the rest of the clock and cleaned the surface with a soft white pencil eraser and got all but one segment going but I don't think it will last long as there were signs of bleeding right up in one corner.
There is a guy that sells OEM clocks on US ebay but I can't find any there at the moment. Each time some go up they get more expensive were about $90 last time I saw any.
10Back to top Go down   Clock Gremlin Empty Re: Clock Gremlin on Tue Oct 07, 2014 9:35 am
Grizzly
Grizzly
Thanks for the hints and tips. If it stops raining long enough I'll go and have a 'poke'.
Wink
