1Back to top Go down   1984 K100RS Empty 1984 K100RS Fri Sep 19, 2014 8:46 pm
John in Phoenix
John in Phoenix
Folks-
I do need to put a battery in the 1984 K100RS.  Which one?  The battery that came with the motorcycle is a Yuasa, and it is huge!  Is a smaller battery available?
The battery cover and hardware are missing as well.  Where should I find these parts?
Thanks!
John in Phoenix
2Back to top Go down   1984 K100RS Empty Re: 1984 K100RS Sat Sep 20, 2014 1:56 am
JR_K100RS
JR_K100RS
G'day John , I use an Odyssey PC680 AGM battery in my 87 KRS , much smaller but heaps of power
JR
3Back to top Go down   1984 K100RS Empty 1984 K100RS battery options. Sat Sep 20, 2014 2:01 am
John in Phoenix
John in Phoenix
JR-
Will the original battery hold-down hardware work with the physically smaller PC680 battery?
Thank you!
John in Phoenix
4Back to top Go down   1984 K100RS Empty Re: 1984 K100RS Sat Sep 20, 2014 2:16 am
JR_K100RS
JR_K100RS
Yes it does John , the PC680 sits in the drop down section in the middle of the battery tray ( the battery can come with a metal heat shield remove that first ) next just flip over the hold down that goes across the top , I've had mine for over 5 years now , great battery with no acid spills etc
JR
5Back to top Go down   1984 K100RS Empty Re: 1984 K100RS Sat Sep 20, 2014 2:36 am
Mossy1200
Mossy1200
Im going to use a lithium battery.
Im not sure if 18 amp hour on a café racer would be enough.
It will have no auxiliary plugs and led tail light blinkers etc.
SHORAI LFX Lithium-Iron Powersports battery, 18Ah PbEq 12V eq, "A" polarity, Case Type 1
Length 5.83"
Width 2.63"
Height 4.13"
Shorai Batteries require a charging system output of 13.1 Volts or higher at idle, and must not exceed 15.2 volts at maximum output.
1984 K100RS A1-imageView Large Image
Specifications:
Weight:2.31 lbs1.05 kgCold Cranking Amps:270
Whats everyone opinion on that as I want to place battery inside the tail hump.
6Back to top Go down   1984 K100RS Empty Re: 1984 K100RS Sat Sep 20, 2014 2:25 pm
brickrider
brickrider
I've seen mixed results with the PC680 batteries.  I've had 3 over the years.  One is absolutely amazing in its longevity (14 years now); one was a great disappointment and the other was only just satisfactory.  There seems to be reason to suspect quality control issues with these batteries. At present I have a Deka AGM battery in my K100RS (thanks EME!).  I doubt I'll ever buy another flooded-cell battery again.
7Back to top Go down   1984 K100RS Empty Re: 1984 K100RS Sun Sep 21, 2014 7:27 am
SEGAFREDO
SEGAFREDO
For me a huge battery means power, I have done the opposite on my K100, a car battery !  Smile
1984 K100RS Mini_568718CIMG27831984 K100RS Mini_615512CIMG2413
8Back to top Go down   1984 K100RS Empty Hope this helps. Fri Oct 10, 2014 1:26 pm
rover17
rover17
I got my battery from Chromebattery.com  last year.
79.00 bucks, No tax and free shipping.
Search for a discount code thru Google and save another 10%.
86' K100RS
Maintenance is as much art as it is science.
