1Back to top Go down   1st ride on resurrected 83 k100  Empty 1st ride on resurrected 83 k100 on Thu Oct 02, 2014 9:06 pm
Dicke
Dicke
Well the old girl got me home..........just.
Had a 100km blast out through round the lake.
 Lost a foot peg after 30km which entered a new time zone when it fell off and is lost forever Embarassed
Right indicator button lost it's spring, so it's quite difficult to turn on.
Bike lost power when coming to traffic lights twice. This was after an extended high throttle run. It didn't stop, just seemed to be lack/ or incorrect fuel pressure. Was thinking fuel pump as mine appears to buzz
But my main concern is a slipping clutch. Tried adjusting but think it may be oil on the plates. It's fine when cold, but as it heats up, starts to slip. Any ideas.
Apart from that, she's old and heavy but comfortable 1st ride on resurrected 83 k100  112350  All in all, great to be back on 2 wheels.
2Back to top Go down   1st ride on resurrected 83 k100  Empty Re: 1st ride on resurrected 83 k100 on Fri Oct 03, 2014 3:34 am
The clutch is probably just worn out. Check the thickness and the steel pressure and drive plate for warped. They tend to dish with heat over time. Oil is possible but there needs to be a lot in the housing to get  on the clutch plate.
Oil usually comes from a hard and worn seal on the rear main.
Take advantage of the situation and lube the gearbox input shaft spline.
4Back to top Go down   1st ride on resurrected 83 k100  Empty Re: 1st ride on resurrected 83 k100 on Fri Oct 03, 2014 6:12 am
Comberjohn
Comberjohn
Check the fuel filter in the tank. They can clog up and restrict the flow if they haven't been changed for quite a while.
Pumps can be quite noisy even when they're ok. With pumps it tends to be a sudden death.
Life is not a rehearsal.
2010 VFR 1200F DCT
2010 R1200GS(gone)
1986 K100 Silver(gone)
2012 K1600GT(gone)
1984 K100 Red(gone)
5Back to top Go down   1st ride on resurrected 83 k100  Empty Re: 1st ride on resurrected 83 k100 on Mon Oct 13, 2014 6:25 pm
Dicke
Dicke
Well getting there....clutch has been adjusted and appears better.
The misfire looks like an injector issue, there was a small amount of corrosion on the terminals. Cleaned them carefully and applied electrical grease. Test run tonight;)
