1Back to top Go down   Exhaust System Empty Exhaust System Wed Oct 22, 2014 10:51 pm
CraigNZ
CraigNZ
Hi,
Have an after market system on my 91 K100.  Will not pass compliance as its too loud Laughing
Have found a complete one online but is off an 83 model.
Anyone know if it would fit?
Craig
1991 BMW K100RS
1999 BMW R1100S
2Back to top Go down   Exhaust System Empty Re: Exhaust System Wed Oct 22, 2014 11:13 pm
You can put them on but the muffler mount requires some changes.
3Back to top Go down   Exhaust System Empty Re: Exhaust System Thu Oct 23, 2014 12:46 am
JR_K100RS
JR_K100RS
Welcome Craig , you could always stuff the can with chicken wire until you get your paper work then rip it out ?
JR
4Back to top Go down   Exhaust System Empty Re: Exhaust System Thu Oct 23, 2014 4:39 am
Be made
Be made
JR_K100RS wrote:Welcome Craig , you could always stuff the can with chicken wire until you get your paper work then rip it out ?
JR
This is a good solution albeit temporary. Here, in NZ, they are changing the decibel rating, going down to 90 as of next year. REAAALY wouldn't be wanting to own a Hardly these days, unless it was one that was as quiet as a beema (and then what was the point of getting a hardly ???)  . . . :-)))
5Back to top Go down   Exhaust System Empty Re: Exhaust System Thu Oct 23, 2014 5:20 am
CraigNZ
CraigNZ
Good idea's. Did once stuff a load of the wire wool pan cleaners down the pipe of the GSX750 to pass the WOF. Did pass although WOF man was giving me funny looks because it failed the day before !
Not done a compliance here in NZ but think it may be tight.... Seen somewhere on here that UK does not require the ABS to work on a two wheeled vehicle?  Not sure if its true here, great if not, but need to find out, anyone know?
1991 BMW K100RS
1999 BMW R1100S
6Back to top Go down   Exhaust System Empty Re: Exhaust System Fri Oct 24, 2014 2:43 am
Be made
Be made
CraigNZ wrote:Good idea's. Did once stuff a load of the wire wool pan cleaners down the pipe of the GSX750 to pass the WOF. Did pass although WOF man was giving me funny looks because it failed the day before !
Ok. ABS . . NZ compliance rules is this. Check your rego sticker. If it has ABS on it then you will have to have the ABS in good working order. If it does not then you are allowed to remove the ABS completely as long as all traces of the system is removed and the bike cannot easily be returned to having ABS.
I removed mine completely because the WOF guy said if it does not go either get it going or remove it.
At the time I did not want to bother tracing the faults source and actually opted out of ABS. Never had it for the previous 30 years, why bother now I said to myself. So it is gone.
BUT . .  if you can fix it get it fixed.
After having tried it, and looking back, removing mine was a mistake. It is worth it's weight in gold and then some
I have a good ABS brain free if you want it
Last edited by Be made on Fri Oct 24, 2014 7:06 pm; edited 1 time in total (Reason for editing : spelling mistake)
7Back to top Go down   Exhaust System Empty Re: Exhaust System Fri Oct 24, 2014 4:41 am
CraigNZ
CraigNZ
Information and an offer I cannot refuse  Wink
Have sent PM
1991 BMW K100RS
1999 BMW R1100S
8Back to top Go down   Exhaust System Empty Re: Exhaust System Fri Oct 24, 2014 6:45 am
The ABS ECU is different on a 8V than 16V, I'm not shure if you can just switch them.
9Back to top Go down   Exhaust System Empty Re: Exhaust System Fri Oct 24, 2014 4:04 pm
Be made
Be made
Inge K. wrote:The ABS ECU is different on a 8V than 16V, I'm not shure if you can just switch them.
Oh yeah . .  forgot about that . . thanks man
10Back to top Go down   Exhaust System Empty Re: Exhaust System Fri Oct 24, 2014 6:27 pm
CraigNZ
CraigNZ
Good point
Thanks for offer anyway, much appreciated
1991 BMW K100RS
1999 BMW R1100S
