1Back to top Go down   Problem with flasher relay Empty Problem with flasher relay on Wed Oct 22, 2014 11:28 pm
My indicators started behaving very eratically over a period of a day. There was no pattern to their behaviour and then they stopped working altogether.
One of the first things I checked were bulbs then fuses. All bulbs ok. Fuse #3 and #7 were blown. I replaced those and they blew again.
I then removed all bulbs including the flasher bulbs in the instruments and the flasher relay unit itself. There was no short to earth. I've also visually checked all the wiring and connectors front to rear. All looks good
I checked both left and right indicator switches on the bars as well as the cancel switch. All function perfectly.
After putting everything back together without the flasher relay, all works fine (no indicators of course) and fuses don't blow. Reinstall the flasher relay and fuses blow again.
My conclusion is that the flasher relay is fritzed.
Have I troubleshooted this problem correctly or have I missed something?
I've found a relay online for $40 plus frt. Is this an ok price?
  Problem with flasher relay Austra12    Fuel:  95 Octane
2Back to top Go down   Problem with flasher relay Empty Re: Problem with flasher relay on Thu Oct 23, 2014 2:48 am
beanoldboy
beanoldboy
hi KH, worn starter brushes can give ya indicator issues also.
http://www.airware.com.au
3Back to top Go down   Problem with flasher relay Empty Re: Problem with flasher relay on Thu Oct 23, 2014 6:09 am
The K is certainly a strange beast when it comes to electrics. Would that cause a dead short tho?
4Back to top Go down   Problem with flasher relay Empty Re: Problem with flasher relay on Thu Oct 23, 2014 6:17 am
Have you tried to re install the flasher relay without the bulbs in the flasher?
Problem with flasher relay Frog15Problem with flasher relay Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
5Back to top Go down   Problem with flasher relay Empty Re: Problem with flasher relay on Thu Oct 23, 2014 12:59 pm
I think your diagnosis points to the flasher relay.  CF's suggestion will confirm that suspicion.  It's possibly the flasher since it is a complex electronic circuit.
The price for the flasher is almost what people ask for a complete harness and relay box.  I bought a harness complete with everything for a 4V k100 for $25.00.  I didn't need the harness; I needed the connectors, wire and components.  Look around Ebay for deals on harnesses, especially broken harnesses as they fetch lower prices. (e.g. cheap harness )
You could try bench testing the relay as shown in this Youtube video:
6Back to top Go down   Problem with flasher relay Empty Re: Problem with flasher relay on Thu Oct 23, 2014 6:54 pm
@Crazy Frog wrote:Have you tried to re install the flasher relay without the bulbs in the flasher?
Good point. I'll try that over the weekend. Thanks
I've been able to pick up a flasher unit pretty cheap. That'll arrive next week. My concern is that if there is a fault somewhere else it may damage the new relay.
7Back to top Go down   Problem with flasher relay Empty Re: Problem with flasher relay on Thu Oct 23, 2014 7:00 pm
Thanks Robmack. I can follow that well enough to rig up a test I think but can anyone tell me what he was saying when he refered to the IC? My German is not so good. Laughing
Last edited by Kaptain Holister on Thu Oct 23, 2014 7:31 pm; edited 1 time in total (Reason for editing : Humor hinzugefügt)
8Back to top Go down   Problem with flasher relay Empty Re: Problem with flasher relay on Thu Oct 23, 2014 7:35 pm
He's (probably) talking about clipping pin 7 on the circled IC to stop hyperflashing.  He is connecting LED signals afterall.
9Back to top Go down   Problem with flasher relay Empty Re: Problem with flasher relay on Thu Oct 23, 2014 7:52 pm
Since both fuses blows as soon you connects the relay I believe that you have
a major short internal in the relay.
You can open the relay (the housing is just pushed on) and look for burnt
components other traces of a short....could be you just need a few new components.
In my opinion you have nothing to lose.
10Back to top Go down   Problem with flasher relay Empty Re: Problem with flasher relay on Thu Oct 23, 2014 8:47 pm
@Inge K. wrote:Since both fuses blows as soon you connects the relay I believe that you have
Yeah I did have a look at that but didn't see anything obvious. I'll try CF's suggestion above to confirm and should have the new relay by middle of next week.
11Back to top Go down   Problem with flasher relay Empty Re: Problem with flasher relay on Sun Nov 09, 2014 6:50 am
Just to finish this off. Found a flasher unit online which I installed today. Blinkers back to normal.
Thanks Very Happy
12Back to top Go down   Problem with flasher relay Empty Re: Problem with flasher relay on Sun Nov 09, 2014 7:03 am
good to have a solve .....good luck
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%OProblem with flasher relay Au-log10
