1Back to top Go down   Suggested replacement for Cooling Fan Empty Suggested replacement for Cooling Fan on Mon Nov 24, 2014 5:04 am
Mark K Boy
Mark K Boy
Hi,
Firstly I will confess my failure incase you are thinking the same thing....
Suggested replacement for Cooling Fan 4327f088440e340607f216a0a5ce3146
Next !!!!!
1.        Buy one of these:-
http://www.ebay.com.au/itm/DC-12V-0-9A-3100RPM-MIN-Rotary-Speed-2-Wire-Cable-Gear-Motor-/301193482990?ssPageName=ADME:L:OU:AU:3160
$AU32 in hand (Brisbane - Australia)
       Remove fan from spigot on original motor. It just pulls off….
2.       Take note of the clearance from the end of the spigot to the flat plain of the housing outer face – see photo.
Suggested replacement for Cooling Fan 93f5192c4758122129b77ec594c80e5b    Suggested replacement for Cooling Fan 27876e743ac5a1f8bf4e0977e5a1d45b
3.       Remove original motor from plastic housing and get rid of the ridges inside the housing so that the new motor fits all the way home. See Photo.  You will have to make a hole at the end of the original housing so that the new wires can come out. (I used a Dermal)
Suggested replacement for Cooling Fan 49e35e7ee4ed74a2c97133cf1a5bc8b1
4.       Once new motor is seated all the way home, and it will fit well. Use a straight edge to work out how much you need to cut off the end of the new motors spigot. See Photo.  Once again I used a Dermal.
Suggested replacement for Cooling Fan F092efc09bc44aa7b19f8321ba658f0a
5.       Drill out the hole in the middle of the fan to allow the new spigot to fit – don’t go to big – it needs to be a tight fit.
Suggested replacement for Cooling Fan Cc5ba305c1fa830d100b504e6573bf36 Suggested replacement for Cooling Fan E1084a80f19823f50fdd5e8ae7992249
6.       I used silicon to mount new motor back into original plastic housing, it fits very well – See photo.
Suggested replacement for Cooling Fan 5d3a0bbcc63252f922f41f5175a3a00a
7.       Push fan onto new spigot – make sure that it can spin freely when fan is placed face down on a flat surface or it may munch into your radiator (not good).
Suggested replacement for Cooling Fan 54efd41e0ded3314c705c484333a1d87  Suggested replacement for Cooling Fan 73f1b74c3ce549befb0de19cbcb25d0e
8.       Be aware of the polarity when reconnecting the wiring – remember you want the fan to SUCK not BLOW, this means you may need to swap the red and the black wires over to get the right air flow direction out of the DC motor.
For those of you that are more Technical than I – note – the new motor is specked at 3100RPM, the original is specked at 4500RPM. If someone sees a big problem with this please let me know, I life in very sunny very hot Brisbane Australia – if anybody is going to have a problem with the slower fan speed then I guess it will be me – I must say though – she really sucks! I do not see a problem.
I hope this helps – I know I had a big problem buying an original motor knowing full well the design is floored to say the least (and no replacement brushes!) Not to mention the cost…….
Keep the shiny side up boys and girls…….
Mark Surman
Keep the shinny side up !
Suggested replacement for Cooling Fan Au-log12
http://www.marksurman.com
2Back to top Go down   Suggested replacement for Cooling Fan Empty Re: Suggested replacement for Cooling Fan on Mon Dec 15, 2014 10:01 pm
Mark K Boy
Mark K Boy
Works very well !!!
Mark Surman
3Back to top Go down   Suggested replacement for Cooling Fan Empty Re: Suggested replacement for Cooling Fan on Mon Dec 15, 2014 10:10 pm
Kyle10
Kyle10
Take a gander at this Spal 6.5" fan conversion  (which I've done to my bike as well).
Cannot relate how pleased I am with the improvement: quieter, far more air movement and a lower profile for enhanced circulation.
A bracket can be made easily from aluminum (found on other thread on same forum).
1985 K100rt 0052183
1983 Honda VF750 007713
4Back to top Go down   Suggested replacement for Cooling Fan Empty Re: Suggested replacement for Cooling Fan on Mon Dec 15, 2014 10:30 pm
Mark K Boy
Mark K Boy
@Kyle10 wrote:Take a gander at this Spal 6.5" fan conversion  (which I've done to my bike as well).
Yep !
Looks great, I would have gone that way.........
Mark Surman
