1Back to top Go down   Heavy Duty Sidecar Shock - Ikon  Empty Heavy Duty Sidecar Shock - Ikon on Fri Dec 05, 2014 3:16 pm
floyd
floyd
1 Ikon rear shock to suit K100 sidecar rig.
Steel body for strength. (normally aluminium)
Heavy duty spring.
Very solid unit.
$150 + post.
If you say yes today I can ship it today, otherwise will be several weeks until I can post.
2Back to top Go down   Heavy Duty Sidecar Shock - Ikon  Empty Re: Heavy Duty Sidecar Shock - Ikon on Fri Dec 05, 2014 6:44 pm
How old is it and can you put up a picture of it please.
3Back to top Go down   Heavy Duty Sidecar Shock - Ikon  Empty Re: Heavy Duty Sidecar Shock - Ikon on Fri Dec 05, 2014 7:23 pm
floyd
floyd
@RicK G wrote:How old is it and can you put up a picture of it please.
Age unknown but is in good Nick. It came off rockmans orange off road side car rig. Pic to follow
4Back to top Go down   Heavy Duty Sidecar Shock - Ikon  Empty Re: Heavy Duty Sidecar Shock - Ikon on Fri Dec 05, 2014 7:50 pm
Was it this one?
Heavy Duty Sidecar Shock - Ikon  Bmw_of10
5Back to top Go down   Heavy Duty Sidecar Shock - Ikon  Empty Re: Heavy Duty Sidecar Shock - Ikon on Fri Dec 05, 2014 8:23 pm
floyd
floyd
Yep that's it
6Back to top Go down   Heavy Duty Sidecar Shock - Ikon  Empty Re: Heavy Duty Sidecar Shock - Ikon on Fri Dec 05, 2014 8:26 pm
That is an IKON design, I was hoping it might be an IKON built to the KONI design.
7Back to top Go down   Heavy Duty Sidecar Shock - Ikon  Empty Re: Heavy Duty Sidecar Shock - Ikon on Fri Dec 05, 2014 11:45 pm
A bit more info.
I know that the K100 shock and the shock from an R80G/S are the same length, but the 80G/S needs a heavier spring (different leverage ratios due to where its mounted).
So this shock with the heavy spring could also find a home on an R80G/S
(A mate had an R80G/S with a nice new Koni on the back but it was very soft, his local friendly bike shop looked into it and found no listing for an 80G/S but the numbers on the shock identified it as K100.  He still has that Koni tucked away but cannot find it much to my disgust)
'87 K100RS/HRD sidecar (1100 motor)  sc25
'92 K100RS-16v (Paint it Black)
Heavy Duty Sidecar Shock - Ikon  K-dogs10
8Back to top Go down   Heavy Duty Sidecar Shock - Ikon  Empty Re: Heavy Duty Sidecar Shock - Ikon on Wed Mar 18, 2015 2:27 am
floyd
floyd
bumpity bump bump.
9Back to top Go down   Heavy Duty Sidecar Shock - Ikon  Empty Re: Heavy Duty Sidecar Shock - Ikon on Wed Mar 18, 2015 4:53 am
hmm.... could be interested in this Floyd
have a good spring here if needed to swap over ...(not sure of size- diameters ) if its compatible
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%OHeavy Duty Sidecar Shock - Ikon  Au-log10
10Back to top Go down   Heavy Duty Sidecar Shock - Ikon  Empty Re: Heavy Duty Sidecar Shock - Ikon on Thu Apr 09, 2015 7:19 pm
Rockman
That outfit was put together in 2010 for the Swan Insurance 24 hr race in SA by Lee McPeake, so I'd say the shock is 2010. It did that race and about 40,000 km on the road before Floyd got it off me.
Last edited by Rockman on Thu Apr 09, 2015 7:21 pm; edited 1 time in total (Reason for editing : so that it made sense)
