1Back to top Go down   ABS Sensor Empty ABS Sensor on Sat Dec 13, 2014 8:55 pm
CraigNZ
CraigNZ
Seems my front ABS sensor has given up.  Got error 3 and no ohms reading between pin 1 and 2 on the ABS plug.
Anyone know the best source for sensors?
Cheers....
Craig
1991 BMW K100RS
1999 BMW R1100S
2Back to top Go down   ABS Sensor Empty Re: ABS Sensor on Sat Dec 13, 2014 9:27 pm
3Back to top Go down   ABS Sensor Empty Re: ABS Sensor on Sun Dec 14, 2014 3:22 am
Craig, I have one off a K75. Somebody on here should be able to tell us if it will fit a K100 and what readings I should get if I test it.
Reason I have it is I removed the whole system as part of bike renovation.
Let me know if you are interested and I'm sure Rick G can tell me how to test it.
4Back to top Go down   ABS Sensor Empty Re: ABS Sensor on Sun Dec 14, 2014 4:07 am
It will fit and as for testing, continuity is the aim but the reading hoonose.
5Back to top Go down   ABS Sensor Empty Re: ABS Sensor on Sun Dec 14, 2014 4:15 am
CraigNZ
CraigNZ
Cheers Guys, Gaz please let me what you want for it, much appreciated, will take it.
Craig
1991 BMW K100RS
1999 BMW R1100S
6Back to top Go down   ABS Sensor Empty Re: ABS Sensor on Sun Dec 14, 2014 6:45 am
The hoonose measurement should be 135 +/- 20 ohms.
7Back to top Go down   ABS Sensor Empty Re: ABS Sensor on Sun Dec 14, 2014 2:19 pm
CraigNZ
CraigNZ
Got 132 ohms on the rear and only 3 on the front.
Its been suggested that the cable ties holding the wire in place sometimes cause the wire to short and that I should remove the ties and see if it makes any difference
1991 BMW K100RS
1999 BMW R1100S
