1Back to top Go down    Injector removal snafu on Fri Jan 16, 2015 11:24 pm
Rustybottom
So I'm trying to get the injectors out, as I suspect they are leaking, and while trying to remove them, only one has popped out of the head, the rest popped out of the rail but one has popped out of the fuel rail. I'm letting things air out in the garage a bit, as a fair bit of gas has leaked out, but is there a method for removing the injectors from the head when not connected to the rail?
Thanks in advance
J
An object at rest, CANNOT BE STOPPED!
1985 K100 cafe faired, 1978 Suzuki GS550
2Back to top Go down    Re: Injector removal snafu on Sat Jan 17, 2015 12:02 am
First, vacuum and clean the engine block around each injector, to remove any collected sand, dirt or debris. The injectors are only pressed into the hole in the block and sealed with an O-ring. try wiggling them. They will eventually loosen and can be removed. If they put up a fight, try WD40 or Jig-a-loo spray as a lubricant. Spray around the injector where is enters the block and wait a bit to allow the fluid to seep in a bit. That should help.
2011 Moto Guzzi V7 Racer
3Back to top Go down    Re: Injector removal snafu on Sat Jan 17, 2015 12:16 am
Rustybottom
Thanks. Got them out. I think I panicked a little as I wasn't expecting gas to pour out at that stage of removal. The plan was to remove them from the rail over a container after pulling them from the head. Got them safely removed.
4Back to top Go down    Re: Injector removal snafu on Sat Jan 17, 2015 12:54 am
@Rustybottom wrote:.... I wasn't expecting gas to pour out at that stage of removal. .....
Fuel should'nt be pouring out or even dripping out at that stage. You need to release the fuel pressure before disconnecting any part of the fuel system. The procedure for removing the injectors is outlinedin this link
EDIT: ps you can easily release the pressure by disconnecting the tank connector and running the engine till it stops. This is also a safety precaution because if fuel spills onto a hot engine you could have a fire on your hands.
Last edited by Kaptain Holister on Sat Jan 17, 2015 1:09 am; edited 1 time in total
1988 K100RT VIN No. 0094680
1989 K100RT VIN No. 0097367 (naked)
1996 K1100RS VIN No. 0451808
Fuel: 95 Octane
Engine Oil:Nulon Full Synthetic 15W50
Gear Box Oil: Nulon Synthetic 75W90
5Back to top Go down    Re: Injector removal snafu on Sat Jan 17, 2015 1:05 am
Rustybottom
Pouring was a little exaggerative. The tank is off the bike, so the fuel that came out was just what was left in the hose and the rail. It came out when the injector popped out of the rail before the block. The I just underestimated how much it all held, maybe a teaspoon at most, and when it was going to come out.
