Go to page : Previous  1, 2, 3
View previous topic View next topic Go down  Message [Page 3 of 3]
101Back to top Go down    Re: Things that BMW put there to annoy me on Mon Jun 02, 2014 5:44 pm
Tenox
Oh I feel more idiot than normally. I have no idea how that plug on TPS is unconnected. I hope it does not need screwdriver on both sides since there is no room. I don't want to break anything so I just ask even it makes me look stupid. How is that unplugged?
I really should get a brand new bike from a dealer and just drive... Hopeless...
102Back to top Go down    Re: Things that BMW put there to annoy me on Mon Jun 02, 2014 6:32 pm
kartooo
@blaKey wrote:"Quite an interesting read as I have gotten used to the 'engine braking' at the TPS allows for and use it a lot. I like the shifting down and braking on the engine before entering a curve and the roll the throttle open and accelerate out of the curve."
85 k100rt current
04 vulcan 1500 classic sold
07 bonneville black sold
05 fjr1300 sold
04 r1150rt sold
91 k100lt sold
r80rt sold
85 K100 sold
103Back to top Go down    Re: Things that BMW put there to annoy me on Mon Jun 02, 2014 6:58 pm
Tenox,
Don't unplug the wire from it. Just loosen the two screws on either side and turn it.
Turn it about 1 or 2 degrees clockwise? (looking from the back of the bike).
You should hear a very faint click. It is now disconnected.
Tighten the screws.
Basic/2 6308802K100CJ05/1988
104Back to top Go down    Re: Things that BMW put there to annoy me on Mon Jun 02, 2014 8:37 pm
You will find a small wire clip just like the clip on the injectors, once that is pulled back the plug will come very easily. Most if not all the FI bits are held in with clips to make a positive connection.
"Every normal man must be tempted, at times, to spit upon his hands, hoist the black flag, and begin slitting throats." from Mencken's 1919 Prejudices
105Back to top Go down    Re: Things that BMW put there to annoy me on Tue Jun 03, 2014 5:00 am
Tenox
@rosskko wrote:Tenox,
Tighten the screws.
Done that (and I think it is anti clockwise), would like to check (with meter) if WOT is OK.
Rick thanks I look in to that.
BMW K100RT Scrambler (86)
106Back to top Go down    Re: Things that BMW put there to annoy me on Tue Jun 03, 2014 7:31 am
Tenox
Thanks Inge and Rick. Measured tps on both bikes and they both have functional WOT.Smile
107Back to top Go down    Re: Things that BMW put there to annoy me on Wed May 06, 2015 9:30 pm
KafeRacer
Unplugged my L-Jet TPS switch today to test the smoothness, it is night and day better. Promptly came home and removed the sensor entirely.
Thanks for the info in this post.
Dave Evans
'Kafe Racer'
kaferacer.wordpress.com
1990 K75RT
1985 K100 Kafe Racer
http://kaferacer.wordpress.com
108Back to top Go down    Re: Things that BMW put there to annoy me on Thu May 07, 2015 12:31 am
Unfortunately you now don't have WOT sw, which tells the FICU to enrich the mix when you are gunning it with the trottle fully open. Better to loosen the TPS and turn counter-clockwise a degree or two till you hear the throttle closed sw. disengage and then tighten back up. Everything else stays the same.
1988 K100RT VIN No. 0094680
1989 K100RT VIN No. 0097367 (naked)
1996 K1100RS VIN No. 0451808
Fuel: 95 Octane
Engine Oil:Nulon Full Synthetic 15W50
Gear Box Oil: Nulon Synthetic 75W90
109Back to top Go down    Re: Things that BMW put there to annoy me on Thu May 07, 2015 2:26 am
bettyswolloks
Glad I stumbled across this thread as I wasn't particularly enjoying riding the Rat around.
Disconnected the TPS at work just to see how the 10 ish mile commute home felt, needless to say any thoughts of getting rid of the bike have now gone!
http://ranfog.co.uk
110Back to top Go down    HMMM on Sun Jun 21, 2015 5:39 pm
6strings
I saw the beginning of this thread this morning, and having nothing better to do I went down to the shop and capped off the FPR vacuum hose and unplugged the TP whatever. I just got back home after putting on about 117 miles. I like how the bike doesn't shut down when you let off the throttle, more controllable in the corners. I'm not entirely sure I noticed any difference relating to the FPR, although it seems like it has a steadier or maybe smoother acceleration. Can't tell that for sure. Any way any excuse to go ride Very Happy
111Back to top Go down    Re: Things that BMW put there to annoy me on Sun Jun 21, 2015 6:18 pm
Comberjohn
There are two separate schools of thought on this one. Personally, I prefer the smoothness without the TPS but you do lose the richer fuel at full throttle.
If you can't loosen the screws on the TPS, and the inside one can be a bugger to get at without removing lots of stuff, you can simply cut the black/white wire that goes to the TPS. That's what I did.
There was some discussion about whether it might be an idea to put a switch in the black/white wire and then you could have the luxury of having either condition at the flick of a switch.
Probably going to incorporate this idea into to the project bike next winter.
Life is not a rehearsal.
2010 VFR 1200F DCT
2010 R1200GS(gone)
1986 K100 Silver(gone)
2012 K1600GT(gone)
1984 K100 Red(gone)
112Back to top Go down    Re: Things that BMW put there to annoy me on Sun Jun 21, 2015 11:15 pm
@6strings wrote:I saw the beginning of this thread this morning, and having nothing better to do I went down to the shop and capped off the FPR vacuum hose and unplugged the TP whatever. I just got back home after putting on about 117 miles. I like how the bike doesn't shut down when you let off the throttle, more controllable in the corners. I'm not entirely sure I noticed any difference relating to the FPR, although it seems like it has a steadier or maybe smoother acceleration. Can't tell that for sure. Any way any excuse to go ride Very Happy
No harm in disconnecting the TPS but if you want to know how it works read this.
I can see there would be some benefit for cruising or commuting mode but my thoughts are that good engine braking improves handling performance when hard cornering.
I've tried it both ways and I prefer it connected but have thought that one day I'll connect a switch into the throttle closed wire.
It is easy just to loosen the TPS and turn counterclockwise till you just hear the switch click then tighten back up. This way you'll maintain the WOT setting on the TPS
As for disconnecting your vacuum line to the FPR... this is not a good idea. Under accelleration, the vacuum increases in the intake manifold which inturn as an effect of increasing the flow of fuel thru the injectors. This means your engine will be running rich and will have poorer performance. Your fuel consumption will go up and you'll probably have fouled plugs after a time which will decrease performance even further.
The FPR adjusts the pressure at the fuel rail to compensate for this change in manifold pressure. The FICU relies on a constant fuel flow rate so it can adjust fuel/air ratios within strict parameters
Fuel: 95 Octane
113Back to top Go down    Re: Things that BMW put there to annoy me on Sun Jun 21, 2015 11:21 pm
Like a few earlier posters here, I just found this thread and did the ccw thing with the TPS this evening.
Then took it out for a quick 20 mile ride on some nearby twisty roads. All I can say is HOLY CRAP!, my k75rt is another bike! Downshifting and engine braking into a turn doesn't have the bike pitching back and forth on the suspension, and I don't have that feeling that it's going to fall over when making a turn at an intersection. For the first time in over a year that I have owned her she doesn't feel topheavy. I actually feel like I am in control at slow speeds.
This thread should be required reading for anyone who is new to Jetronic equipped bricks.
Can this fix be applied to a 16 valve K100RS with the Motronic? Mine has that nasty on/off thing going on as well.
1994 K75S
1992 K100RS
114Back to top Go down    Re: Things that BMW put there to annoy me on Mon Jun 22, 2015 12:15 am
Unfortunately the Moronic injection needs the TPS because it is a real TPS and is required for metering the fuel.
115Back to top Go down    Re: Things that BMW put there to annoy me on Mon Jun 22, 2015 12:45 am
Hi .75
I don't get that pitching on my suspension and would say it's not normal (I guess you're talking about front forks??). Maybe old fork oil? or you may need a different grade.
Fuel: 95 Octane
116Back to top Go down    Re: Things that BMW put there to annoy me on Mon Jun 22, 2015 1:12 am
Kaptain Holister wrote:Hi .75
Kapt. The pitching is the same as that which occurs under any deceleration. Whether from brake application or engine braking. Two fork oil changes with BMW fork oil in the past 12,000 miles have had no effect on the pitching. It is the thing I most dislike about the bike.
It's possible that my later model K75 with long travel forks is more susceptible to pitching than your bike. Riding style may have some bearing as well as I seem to use a fair bit of engine braking. At 67,000 miles it may be my springs are shagged as well. The higher center of gravity which is the result of the massive RT fairing certainly doesn't help either.
All I know is that last evening the bike felt better than it has since I got it.
1994 K75S
1992 K100RS
117Back to top Go down    Re: Things that BMW put there to annoy me on Mon Jun 22, 2015 1:43 am
.75 if you're getting pitching in the front forks with engine braking on the rear wheel then it would have to be much worse when applying the front brakes. In any case, springs could be shagged but maybe you just need a heavier viscosity oil. There's some interesting info re fork oil viscosities HERE
Also there's some discussion here on quantities and how that can affect handling with regard to the suspension 'diving'. There are different forks fitted to Ks which require different quantities of oil.
This particular post is worth a read
EDIT:
Here's the original article
Also an interesting thread from another forum
Last edited by Kaptain Holister on Mon Jun 22, 2015 1:51 am; edited 1 time in total (Reason for editing : added links)
Fuel: 95 Octane
118Back to top Go down    Re: Things that BMW put there to annoy me on Mon Jun 22, 2015 9:22 am
Thanks for the advice Kapt.! I am currently using fork oil with a viscosity of SAE 10. Anything higher and the front end gets awfully harsh on rough pavement(which is very common here in the Communist People's Republic of New York). Can't tell you off the top of my head how much is in them, but I followed the spec in the owner's manual which matched the quantities specified in other sources. I am confident I have the right amounts of clean fluid in both fork tubes.
From reading a bit on the subject, this pitching is a fairly common problem. Disabling the TPS no throttle function has gone a long way toward mitigating it. My K now handles like a normal bike in corners.
1994 K75S
1992 K100RS
119Back to top Go down    Re: Things that BMW put there to annoy me on Mon Jun 22, 2015 12:25 pm
@Point-Seven-five wrote:Like a few earlier posters here, I just found this thread and did the ccw thing with the TPS this evening.
good work .75
enjoy !!!
120Back to top Go down    Re: Things that BMW put there to annoy me on Mon Jun 22, 2015 10:41 pm
good work .75
enjoy !!!
Rode her 60 miles to work today. My enjoyment of this ride has hit a new level. Can't describe how much better she feels in turns.
1994 K75S
1992 K100RS
121Back to top Go down    Re: Things that BMW put there to annoy me on Mon Jun 22, 2015 11:03 pm
Glad to hear its sorted and you're enjoying the ride .75
Fuel: 95 Octane
122Back to top Go down    Re: Things that BMW put there to annoy me on Mon Sep 24, 2018 11:17 pm
MarcS
Another win. I just mis adjusted my TPS and did a slow 1st/2nd gear ride around on some rough dirt tracks. It is much easier to control now bounce bounce bounce bounce
K100rt ex plod bike 5/1990.
I have no problem with authority. Just some of the morons that are paid to enforce it.
123Back to top Go down    Re: Things that BMW put there to annoy me on Tue Sep 25, 2018 6:05 am
124Back to top Go down    Re: Things that BMW put there to annoy me on Tue Sep 25, 2018 8:22 pm
I'm definately going to give that a try. The local council replaced a crossroads with a roundabout (okay, it did need it) but the entrance and exits are so sharp it's nearly impossible to put the brick through it at any speed because of the TPS operation. The Bandit now... that's a different beast altogether on that roundabout.
125Back to top Go down    Re: Things that BMW put there to annoy me on Thu Sep 27, 2018 10:12 am
Woodie
I popped the connection the TPS yesterday and had a good run - WOW! I will reconnect and adjust the low end out of the switch. This, for me at least, is a great improvement with low speed handling. Every time I leave my yard I have had a very non-graceful lurchinginclined off camber turn on (usually wet) grass. I always passed this off as something inherent in the shaft drive, a stiff throttle cable that probably should be replaced, and my own lack of riding finesse. This bit of advice should be included with what every new early K owner needs to be aware of I think.
I'm glad you found this Marc!
1985 K100RT
52667
"Keep your stick on the ice. We're all in this together." Red Green
126Back to top Go down    Re: Things that BMW put there to annoy me on Thu Sep 27, 2018 7:52 pm
MarcS
Ha ha. Yes Woodie. My wife was forever headbutting me in the back of the helmet on dirt roads. Riding on sandy tracks was a nightmare but all good now
View previous topic View next topic Back to top  Message [Page 3 of 3]
