1Back to top Go down   How do you balance clutch plates?? Empty How do you balance clutch plates?? on Sun Feb 01, 2015 4:34 pm
gabriel
Hi everyone.
I've been searching the motobins and motoworks BMW websites for a replacement pressure plate.
I noticed the plates have sections drilled out of it in different locations.
I purchased a pressure plate and when I compared it with the old plate I noticed the drilled out section are in different locations.
Wondering how would it be possible to "balance " the plates in that situation?
2Back to top Go down   How do you balance clutch plates?? Empty Re: How do you balance clutch plates?? on Sun Feb 01, 2015 7:36 pm
In my experience they are balanced then put together as a pack and checked then marked to keep that position and installed.
I have not come across any plates that have needed work after the initial balance which is done at the factory.
3Back to top Go down   How do you balance clutch plates?? Empty Re: How do you balance clutch plates?? on Sun Feb 01, 2015 9:37 pm
gabriel
Unfortunately I bent one of the pins.
For those who do purchase replacement parts, is it possible for them to be balanced.
Is it possible for the bent pin to be straightened?
4Back to top Go down   How do you balance clutch plates?? Empty Re: How do you balance clutch plates?? on Sun Feb 01, 2015 10:02 pm
All of the clutch components have individual part numbers and are not sold in a set so it stands to reason that you can whack any component of the four main pieces in any manner they fit.
The plates needing balancing are balanced individually.
1987 K100RS, '89 K100 w/K1100RS engine, '93 Framed K11/K12 engine 'Big Block', '96 K1100RS, '09 K1300GT, '13 R1200RT-P, '95 R100 Mystic & '77 R75/7.
5Back to top Go down   How do you balance clutch plates?? Empty Re: How do you balance clutch plates?? on Sun Feb 01, 2015 10:07 pm
You do not need to balance them it has been done at time of manufacture.
Don't try to repair the pin it will fracture and probably break at a later time.
6Back to top Go down   How do you balance clutch plates?? Empty Re: How do you balance clutch plates?? on Mon Feb 02, 2015 12:06 am
gabriel
Thnk you for your replies.
The last two in particular have put my mind at ease.
I found it difficult to understand the reasoning for the marked components.
I have also watched many videos where the plates are installed in no particular order.
Is a second hand part an option? I've heard that these plates often warp or should I purchase a new plate.. They're not cheap!
7Back to top Go down   How do you balance clutch plates?? Empty Re: How do you balance clutch plates?? on Mon Feb 02, 2015 2:04 am
The steel plates get a dish to the centre check it with a straight edge. I have about 6 clutch sets here and all have quite a dish in them.
8Back to top Go down   How do you balance clutch plates?? Empty Re: How do you balance clutch plates?? on Thu Feb 12, 2015 3:49 am
gabriel
Hi to all the forum members
I purchased a pressure plate from Motoworks.
I noticed a mark on the plate, similar to a white paint brushstroke.
The pressure plate with the mark is the one with the three pins.
The other plate didn't have any mark.
The mystery deepens?
Gabriel
Ps I also purchased optimal paste..it's a silver colour. Can I use it for all of the splines?
9Back to top Go down   How do you balance clutch plates?? Empty Re: How do you balance clutch plates?? on Thu Feb 12, 2015 9:58 am
Optimol silver is the stuff for all of the splines. It's almost as good as Honda's Molykote 60.
There's no need to be concerned with balance, or drilled balance holes, on individual clutch plates/discs.
10Back to top Go down   How do you balance clutch plates?? Empty Re: How do you balance clutch plates?? on Thu Feb 12, 2015 1:17 pm
That tube of Optimol will last for years. It looks expensive but small amount goes a long way.
11Back to top Go down   How do you balance clutch plates?? Empty Re: How do you balance clutch plates?? on Thu Feb 12, 2015 3:44 pm
gabriel
Hi guys
Thanks for your responses.
I had another look at the two pressure plates and both of them have been marked with white paint.
Apologies for the omission.
I was concerned about my optimal paste. Mist references point to a white paste but I won't be concerned.
12Back to top Go down   How do you balance clutch plates?? Empty Re: How do you balance clutch plates?? on Thu Feb 12, 2015 3:52 pm
White Optimol is the older goo, grey is the latest and greatest.
13Back to top Go down   How do you balance clutch plates?? Empty Re: How do you balance clutch plates?? on Fri Feb 13, 2015 4:11 pm
gabriel
Thanks...
14Back to top Go down   How do you balance clutch plates?? Empty Re: How do you balance clutch plates?? on Sat Feb 28, 2015 7:28 pm
gabriel
Hi
I have a question about the friction plate. I have purchased new pressure plates and a friction plate.
It's not n original part. It's made Bryan Italian company.
Any concerns about this situation.
Gabriel
15Back to top Go down   How do you balance clutch plates?? Empty Re: How do you balance clutch plates?? on Sat Feb 28, 2015 8:36 pm
We have seen worse in here......that was someone that wanted to mount Chinese  How do you balance clutch plates?? Liten_10
parts on the K.....he isn't a member anymore.     How do you balance clutch plates?? Laughi10
Have no idea about the quality level on the part that Gino have made.
16Back to top Go down   How do you balance clutch plates?? Empty Re: How do you balance clutch plates?? on Sat Feb 28, 2015 8:36 pm
No need for any concern there. I have one in my K1100 and it's quite good.
17Back to top Go down   How do you balance clutch plates?? Empty Re: How do you balance clutch plates?? on Tue Mar 10, 2015 5:55 pm
floyd
floyd
Just for more moral support.
When I reassembled my K I had no reference for the balancing of the separate discs. I cant recall weather I just threw it all together randomly or if I put the drilled balance bits all pointing away from each other...
Either way, no issues in terms of balance at all. My bike runs smooooth as.
Good luck mate
