1Back to top Go down   K1100LT cooling fan electrics query Empty K1100LT cooling fan electrics query on Mon Feb 23, 2015 3:45 am
DeRodster
DeRodster
In the process of replacing cooling fan motor
I have lower fairing removed and am working my way towards removing radiator.
Question is about fan wiring.
I presume the + is switched thru the thermostat,
but can I assume the -neg is grounded to the chassis somewhere
and if I do a continuity test with the multimeter it'll indicate this or ?
1992 K1100LT 6455194
1943 BSA WM20
1979 Yamaha DT-175
1974 Triumph 3TA / 5TA
1974 Honda 100
1969 Honda 50
2Back to top Go down   K1100LT cooling fan electrics query Empty Re: K1100LT cooling fan electrics query on Mon Feb 23, 2015 4:04 am
The power feed to the fan comes from the fan relay which is managed by the Motronic unit.
3Back to top Go down   K1100LT cooling fan electrics query Empty Re: K1100LT cooling fan electrics query on Mon Feb 23, 2015 4:08 am
DeRodster
DeRodster
Thanks Inge,
I guess that means my simple  earth concept is not a runner
on the other hand you may be able to tell me which side right or left is positive,
and I assuming the fan motor wiring terminals are horizontal (knowing my luck they're not)
Rod
1943 BSA WM20
1979 Yamaha DT-175
1974 Honda 100
1969 Honda 50
4Back to top Go down   K1100LT cooling fan electrics query Empty Re: K1100LT cooling fan electrics query on Mon Feb 23, 2015 4:14 am
Yellow/violet wire is power, brown wire is ground...connector you find under the tank.
5Back to top Go down   K1100LT cooling fan electrics query Empty Re: K1100LT cooling fan electrics query on Mon Feb 23, 2015 4:24 am
DeRodster
DeRodster
Brilliant
Thanks Inge
1943 BSA WM20
1979 Yamaha DT-175
1974 Honda 100
1969 Honda 50
6Back to top Go down   K1100LT cooling fan electrics query Empty Re: K1100LT cooling fan electrics query on Mon Feb 23, 2015 11:41 am
If you put 12V to the fan alone, even backwards it should run, brown+ and yellow/violet-
(after refurbish I let them run 10 minutes both ways)
K1100LT cooling fan electrics query Eu-log10  K1100RS/LT - R1200RT - R1100RS (RIP) - Cagiva SST 350 Ala Verde
