1Back to top Go down   Fuel pump rubber mounting saddle  Empty Fuel pump rubber mounting saddle on Mon Mar 23, 2015 9:32 am
K7oaks
K7oaks
I need the rubber saddle that the fuel pump sits in for a 1984 K100.
2Back to top Go down   Fuel pump rubber mounting saddle  Empty Re: Fuel pump rubber mounting saddle on Mon Mar 23, 2015 12:47 pm
Ken
Is this what you are looking for? Its on www.motorworks.co.uk .? If it is let me know, I can have a new one to me in 2 days and will mail it down to you. Mail from here is cheap.
Olaf
Vibration damper for fuel pump pre 01/93 | FUA64628
Fits K75, K75S, K75C, K75RT, K100, K100RS, K100RT, K100LT, K100RS 16v, K1, K1100LT
Fuel pump rubber mounting saddle  T
Fuel pump rubber mounting saddle  Magnify_large  Larger Image
If you are interested in an equivalent used part see FUK61577 . Please note that if a used part has no shopping basket icon you will need to telephone us to check availability and place your order
1997 K1100LT 0188024 Wotan Mystic Red 689 58,645 now 100,380 miles
1983 K100RS 0011171 Fricka 606 29,495 miles Damn K Pox Its a Bat outta Hell No 33,600 miles
3Back to top Go down   Fuel pump rubber mounting saddle  Empty Re: Fuel pump rubber mounting saddle on Mon Mar 23, 2015 4:00 pm
Models before 05/85 have a different rubber damper which is NLA.
Then you must change to the newer version prefilter, damper and holder.
And blind the spigot for the vent hose.
4Back to top Go down   Fuel pump rubber mounting saddle  Empty Re: Fuel pump rubber mounting saddle on Mon Mar 23, 2015 4:06 pm
Inge
Thanks for that one.
Does that change in 1985 occur when the tank was changed from bolt down to two clips? Or is it earlier? My question is because my K100RT is 08/84 and if its the right one for mine as well I was going to order 2 of them and mail on to Ken for his RT.
5Back to top Go down   Fuel pump rubber mounting saddle  Empty Re: Fuel pump rubber mounting saddle on Mon Mar 23, 2015 8:29 pm
K7oaks
K7oaks
Got one !!! Thanks all the same Olaf & Inge K
