1Back to top Go down   MA 2.1 Motronic Control Unit needed Empty MA 2.1 Motronic Control Unit needed on Tue Mar 24, 2015 7:40 am
Packo
Packo
Does anyone have a MA 2.1 Motronic unit for 10/92 K1100LT they would be happy to sell ???
Inge K advises that the item I need is one of the following versions:
A Motronic MA 2.1 unit with a yellow Bosch label which has # 0 261 200 709.
Or silver label with the last seven digits of the OEM # on 13 61 1 464 479.
According to a cross reference, OEM # 13 61 1 464 530 is similar.
I can also use one with a yellow Bosch label # 0 261 200 250 and OEM #  13 61 1 464 417.
Or blue Bosch label 0 261 200 250  and OEM # 13 61 1 464 289.
According to a cross Reference, Bosch #  0 986 261 091 and 0 986 261 094
is similar.
I know # 1 464 479 works as I have borrowed a unit with that number for testing.
Please PM me with the details if you have something
______________
83 K100 HRD Outfit
77 R100RS
1992 K1100 Outfit
1983 K100
2Back to top Go down   MA 2.1 Motronic Control Unit needed Empty Re: MA 2.1 Motronic Control Unit needed on Tue Mar 24, 2015 8:22 am
PM sent
3Back to top Go down   MA 2.1 Motronic Control Unit needed Empty Re: MA 2.1 Motronic Control Unit needed on Tue Mar 24, 2015 11:52 pm
The unit I have is a yellow label 0 261 200 250 so as Inge has said it should be the one. It does work I have run it in my 1993 K1100.
4Back to top Go down   MA 2.1 Motronic Control Unit needed Empty Re: MA 2.1 Motronic Control Unit needed on Wed Mar 25, 2015 2:33 am
Packo
Packo
Rick,
So far so good!!!!
When I get home in a couple of hours I will get the numbers of my MA 2.2 and let you know
______________
83 K100 HRD Outfit
77 R100RS
1992 K1100 Outfit
1983 K100
