You can now order the forum stickers. Login and go to the "members only" forum. This is not available for guests yet....
1Back to top Go down    How many SpeedBleeders required? on Tue Apr 07, 2015 7:12 pm
I'm fitting speed bleeders to my K75. I've dual four-pot non-ABS up front and the single 2-pot rear. Will this require one Speed Bleeder per caliper (3 total) or can I get away with one front, one rear (2 total)? Reason is they are sold in pairs.
2011 Moto Guzzi V7 Racer
2Back to top Go down    Re: How many SpeedBleeders required? on Tue Apr 07, 2015 8:33 pm
Good question, Robert. I bought two sets and have a spare. It has never occurred to me that you only need one at the 'very end' of the brake house circuit you're bleeding, but it may be true.
I just manually filled and bled the front brakes on the Big Block project (four pot Brembos, Spiegler hoses with a factory splitter under the fork brace, and 20mm M/C) and after topping off the master cylinder and opening the left side calliper's speed bleeder it was pumping bubbles and then nothing but clear fluid. Opening and squirting the right hand side a few slow, easy strokes had it firm and fully functional in five minutes.
Rolling Eyes
Last edited by Two Wheels Better on Tue Apr 07, 2015 10:34 pm; edited 2 times in total
'77 R75/7-1000cc, '87 K100RS, '93 w/K12 Big Block, '94 R100 Mystic, '03 K1200GT, '04 R1150RT, '06 K1200R, '07 K1200R & '09 K1300GT
3Back to top Go down    Re: How many SpeedBleeders required? on Tue Apr 07, 2015 9:38 pm
My '94 75RT only has one bleeder on the front. It has a crossover line between the calipers and the bleeder is on the downstream caliper only. I don't even see a place to install a bleeder on the other.
If your bike is like my K100 where the lines split and go individually to the calipers, then you will need two front bleeders.
If you are looking on eBay, I believe there are sellers who will sell three or more and combine shipping.
1994 K75S
1992 K100RS
4Back to top Go down    Re: How many SpeedBleeders required? on Tue Apr 07, 2015 10:44 pm
Thanks for the input.
I'm supporting local bike shops by shopping retail. They only stock and sell pairs. My front brakes have a T-splitter on the fork brace and single lines to each front caliper. I guess that means one Speed Bleeder per caliper -- three in total. I can see having only one Speed Bleeder on the last caliper for those setups with a crossover pipe, because the crossover pipe occupies the place where the nipple would go.
