You can now order the forum stickers. Login and go to the "members only" forum. This is not available for guests yet....
1Back to top Go down    Dead speedo on Fri 17 Apr 2015 - 18:05
Aussiebob52
Have a dead speedo/odometer/trip meter on my 1993 K1100LT. Have looked through all the suggested lists and tech sites for solutions, with no success. So in the end have taken it to a company specialising in repairing guages and meters, where they have bench tested it, to find it is faulty. Got a quote for $250 to fix just the speedo or $350 to fix the the odometer, trip meter as well.
So am getting both fixed. Have looked online for second hand one's and works out at least the same cost, plus postage to Australia. Brand new one's are dearer, or in MPH which isn't much good out here as we use KPH speed limits. I don't know exactly whats wrong with, but will try to find out when I pick it up and will post anything I find out on here for others that may have the same problem speedo.
2Back to top Go down    Re: Dead speedo on Fri 17 Apr 2015 - 18:50
interesting issue bob
yeah would like to hear of the outcome
my fist suspicion is that the gear on the odo have split ...lost teeth
but I wouldn't hold that as the reason for the failure of the speedo
often found to be In the film circuit board ...and or connections to the motor assembly
also the input to instruments connections
just out of interest I was looking at some instrument diagrams today (for some investigation into tacho issues actually ) but remembered this
you will notice the film circuit board connected to pins that then go to the electronics of the mechanism ...some times the circuit connection become open circuit ...often repaired by installing a bit of wire from the input to the meters connection points
the motor assembly drives off the film connector towards the top of the picture ... and could also have intermittent connections
3Back to top Go down    Re: Dead speedo on Sat 18 Apr 2015 - 10:21
That could be the problem with the instruments I sent you Charlie.
1983 K100basic vin 0003960 colour red
1987 K100RT vin 0094685 colour, orange peel, sorry, pearl
4Back to top Go down    Re: Dead speedo on Sat 18 Apr 2015 - 18:10
will keep that in mind stan ...thanks for the heads up
